multiple join {Scanned}
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Dec 14 18:50:18 EST 2005
It might be that if you're not hitting CVS head then the changes aren't there yet. Check the top of mapjoin.c to be sure. There should only be a single relatively recent change. I'm not a Windows guy so will be of little help getting anything running there.
Steve
>>> Siki Zoltan <siki at AGT.BME.HU> 12/14/05 6:30 PM >>>
Hi Steve,
Thank for your answer.
I've tried 4.8.0beta but it also cause illegal operation on win xp prof.
I would like to debug mapserv with Visual Studio but I failed to compile
it with source info. Is there any howto about it?
Thanks
Zoltan
On Wed, 14 Dec 2005, Steve Lime wrote:
> I believe there have been some bug fixes along this line applied to both the pending 4.8 release and the 4.6.2 release. If you can get a win32 version of either of those I think you should be fine.
> Steve
> >>> Siki Zoltan <siki at AGT.BME.HU> 12/14/05 4:38 AM >>>
> Hi,
> I get in trouble with multiple join.
> It works on linux but fails several times on win32, but not always.
> I get unhandled exception 0x7c911e58 in mapserv.exe 0xc0000005
> Access violation reading location 0x2f3c3534 using ms4w.
> On linux I use
> MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> On win32 I use (ms4w)
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> -- my layer definition in map file ---
> LAYER
> NAME "kafold"
> DATA "alapterkep/kafold"
> STATUS ON
> GROUP "telkek"
> TYPE POLYGON
> MAXSCALE 15000
> CLASS
> COLOR -1 -1 -1
> OUTLINECOLOR 0 0 0
> END
> TOLERANCE 0
> # template is set though URL
> # TEMPLATE "telek_cim.html"
> # HEADER "telek_cim_header.html"
> # FOOTER "telek_cim_footer.html"
> JOIN
> NAME cim
> TABLE "cimek/ujcimek1.dbf"
> FROM HRSZ
> TO HRSZ
> TYPE multiple
> TEMPLATE "cim_template.html"
> END
> END
> -- telek_cim.html ---
> [join_cim]
> -- cim_template.html --
> <tr>
> <td valign="top">[HRSZ]</td>
> <td valign="top" align="right">[JOGTER]</td>
> <td valign="top">[F_TIP]</td>
> <td valign="top">[VALTSZ]</td>
> <td valign="top">[cim_IRSZAM]</td>
> <td valign="top">[cim_CIM]</td>
> <td valign="top">[cim_HATSZAM]</td>
> </tr>
> Any idea?
> Thanks
> Zoltan
