buffer around vector features
Lowell.Filak lfilak at MEDINACO.ORG
Thu Dec 15 08:06:16 EST 2005
william paul writes:
> Hello:
>   It is possible to create buffer around a vector feature? and use the buffer to select the features insight the buffer?
>   Does someone have a working example?
>   Thank you in advance
William,
You can do all of that with SWIG MapScript except select "within", it only
does a "passthru" method.
I can dig up a sample if you are interested in using MapScript.
Lowell
