Foundation and Mapserver MAP file manag e tool
Gerry Creager N5JXS gerry.creager at TAMU.EDU
Thu Dec 15 09:41:20 EST 2005
I'm getting in late on this, but what're the chances of using GML for
this functionality instead of trying to roll our own?  GML's already OGC
recognized.  Done right, it could cover most of the "stuff" we're
interested in, and could be readily extended (and OGC ratified,
probably) if we needed to.
Gerry
Gregory S. Williamson wrote:
> Well, nobody would have to use the db mode, but I personally would find that easier than XML, which I find notoriously sensitive to misplaced spaces and the like. The readability of binary combined with the terseness of ASCII.
> That said, XML might give some excellent options in communicating map data to other systems, GIS or not. The database would more less transportable, but perhaps would gain in some other ways (ACID aspects, internal safety/sanity checks, etc.). Such a db interface would want to use fairly limited SQL to support various databases such a Postgres, Oracle, MySQL, etc.
> In general I've found that any non-trivial map is semi-hard to edit and read, and tools to help automate map file production would be a great help. It would allow for more customization for different users, IMHO.
> Greg Williamson
> DBA (natch)
> GlobeXplorer LLC
> -----Original Message-----
> From:	UMN MapServer Users List on behalf of Umberto Nicoletti
> Sent:	Thu 12/15/2005 3:42 AM
> To:	MAPSERVER-USERS at LISTS.UMN.EDU
> Cc:
> Subject:	Re: [UMN_MAPSERVER-USERS] Foundation and Mapserver MAP file manag e tool
> The trouble with databases is that they could be more difficult to
> edit by hand than a xml file. Withoud a db involved the user would not
> have to learn sql to be able to modifiy a map definition directly.
> [OT]
> In my app I use and XML to Java objects mapping tool called digester
> and then use Velocity templates to generate the map file: Velocity
> templates are also very intuitive and would enable users to mantain
> many different versions depending on mapserver version for instance.
> [/OT]
> Regards,
> Umberto
>>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
>>Behalf Of Jeroen Ticheler
>>Sent: Thursday, December 15, 2005 11:19 AM
>>manag e tool
>>Fully support this! I'm also looking for a DTD/schema that can
>>produce valid Map files.
>>MapServer may have to be modified in some parts to make sure it is
>>consistent throughout when running map services based on files
>>created by the schema.
>>Also OGC specific parts have to be included in such schema to make
>>sure we can quickly generate valid map files with OGC WMS/WCS and WFS
>>support.
>>I would like to use such such schema to create XSL transformations of
>>metadata (ISO19115) stored in GeoNetwork opensource to generate map
>>files for data producing OGC services (even on the fly).
>>I would also use it to do XSL transformations of AXL documents I
>>export from ArcMap using the MXD2AXL I developed to create map files
>>straight out of ArcMap.
>>Ciao,
>>Jeroen
>>On 15 Dec 2005, at 00:01, Bob Basques wrote:
>>>Steve,
>>>Ok, now we're talking, XML!! Yeah, I even have a body here I can
>>>put to work on something like this with some direction from the
>>>rest of the community.
>>><snip>
>>Hi,
>>I have been using XML / XSL for a while to create map files for our services.  From my experience it is easier to use a database (hypersonic is very light) or MySQL and then use the SQL extensions for stylesheets (http://xml.apache.org/xalan-j/extensionslib.html) this broadens the applications of this technology, e.g. you could have web app updating the database, eclipse reading either the database or xml file or 'data objects'.  Whilst a schema enforces the correctness of an XML file, it doesn't support the transactional features of a database, allowing you to rollback etc.
>>XSL is definitely the way to go though (IMHO), it is easy to use and learn.
>>Norman
> !DSPAM:43a156c425721133564134!
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
