MAP file highlighter for SciTE
Gregory S. Williamson gsw at GLOBEXPLORER.COM
Fri Dec 16 08:47:11 EST 2005
I've dowloaded this and put the properties file into the SciTE directory, edited the global properties file and added references to the new file, e.g.
$(filter.lua)\
$(filter.map)\    <-- new
$(filter.matlab)\
Lu&a|lua||\
Map|map||\
Matlab|m.matlab||\
import lua
import map
import matlab
And it works like a charm !
If there is anything else that needs doing perhaps you could let us know.
Thanks for this nifty contribution!!
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From:	UMN MapServer Users List on behalf of Ruslan Nuryadin
Sent:	Fri 12/16/2005 5:08 AM
To:	MAPSERVER-USERS at LISTS.UMN.EDU
Cc:
Subject:	[UMN_MAPSERVER-USERS] MAP file highlighter for SciTE
I made MapServer's MAP file syntax highlighter for SciTE text editor, based
on Lua syntax highlighter.
The file is here:
http://www.geocities.com/ruslannuryadin/mapserver/map.properties.tgz
ruslan
!DSPAM:43a2bc818771344913351!
