Generating images only
Ken Lord
kenlord at GMAIL.COM
Fri Dec 16 17:14:44 EST 2005
Hi Bob,
Your application could call mapserv.exe or shp2img.exe from within a
command shell with the appropriate parameters, and then grab the image
it generates.
Cheers,
Ken Lord
Vancouver BC
On 12/16/05, Bob Basques <bob.basques at ci.stpaul.mn.us> wrote:
> Brian Peschel wrote:
> >I have an application that needs to display a map image. I was thinking of
> >using MapServer to generate that image for me. I have worked through the
> >O'Reilly book and most of the tutorial and I stumbled across a question
> >which I am sure is answered somewhere, but I didn't find it searching
> >through the online documentation at http://mapserver.gis.umn.edu
> >1) Is there a way to generate just the image? I don't want all the
> >surrounding web page (ie the global.html file) just the image. My
> >appliction will handle all the zooming, hull size, etc. Is there a
> >parameter to the CGI to say just generate the image and not the HTML? I am
> >dealing with an applet and would like to skip the step of reading the HTML
> >to get the image info and make a second request for the image.
> Look into using the CGI version of the MapServer.
> bobb
> >2) Is there documentation for the various *Script interfaces? I have some
> >interest in using MapServer inside a C++ application, again, just to
> >generate the images displayed.
> >Thanks in advance.
> >Brian
