Strange looking gdalinfo output
Frank Warmerdam warmerdam at POBOX.COM
Sat Dec 17 10:34:02 EST 2005
On 12/16/05, Stephen Davies <sdc at sdc.com.au> wrote:
> I recently purchased a collection of images from the local State
> Government. The images were provided in both ECW and TIF formats.
> In particular, the false easting/northing values are swapped and the
> extent lat/long values are quite different.
> Could this be a problem with gdalinfo or is the data wrong?
Stephen,
This would appear to be a serious bug in GDAL's ERMapper
coordinate system handling (though it could still be a data
production error).  Could you file  bug on it?   If the files are
too large to provide to me, it would be helpful if you could:
 o Run "listgeo" on the GeoTIFF file and record the results.
    Listgeo is part of the libgeotiff package, and should be
    included in FWTools releases.
 o Run gdalinfo with the "--debug on" commandline switch
    against the ECW file, and record the results.  It should
    include info ERMapper projection and datum name I can
    use.
The bug should be filed in the GDAL Bugzilla.
Best regards,
