MAP file highlighter for SciTE
Ruslan Nuryadin
nuryadin at GMAIL.COM
Mon Dec 19 02:05:35 EST 2005
Gregory,
Thanks for your additional setup procedure info. I was forget to put that on
my first email.
Against the todo list: there's a small problem with commenting. Lua's
comment started with '--' (two minus signs), while MapServer's map file
comment started with '#'.
I used this trick: every (SciTE's generated) comment started with '#--', in
order to comply to both map file commenting style and Lua's comment
highlighter :)
I'll be very appreciate if somebody find better solution regarding this
problem without the need to modify Lua lexer.
Best regards,
Ruslan Nuryadin
On 12/16/05, Gregory S. Williamson <gsw at globexplorer.com> wrote:
> I've dowloaded this and put the properties file into the SciTE directory,
> edited the global properties file and added references to the new file,
> e.g.
> $(filter.lua)\
> $(filter.map)\ <-- new
> $(filter.matlab)\
> Lu&a|lua||\
> Map|map||\
> Matlab|m.matlab||\
> import lua
> import map
> import matlab
> And it works like a charm !
> If there is anything else that needs doing perhaps you could let us know.
> Thanks for this nifty contribution!!
> Greg Williamson
> DBA
> GlobeXplorer LLC
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051219/467e622b/attachment.html
