HELP-Virtual Spatial Data
Skalski Artur - askals
Artur.Skalski at ACXIOM.COM
Mon Dec 19 03:17:53 EST 2005
Try to modify your mapfile like this, I had the same problem and it helped:
LAYER
NAME "sorento"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "virtual.ovf" # the name and path to the virtual.ovf file, relative to shapepath may
work?
DATA "sorento" # the name of the OGRVrtLayer
STATUS DEFAULT
CLASS
STYLE
SYMBOL "circle"
SIZE 6
COLOR 255 0 0
END
END
END
regards
Artur Skalski
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Frank Fica
Sent: Monday, December 19, 2005 6:51 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] HELP-Virtual Spatial Data
Hello,
I'm testing an OGR ODBC connection to my postgresql database to map Lat and Lon columns, but
when I test my file.map I only get a blank screen and no errors.
When I test with ogrinfo I get all the columns listed including the new POINT column with my
coordinates, works fine.
Here's my ovf file:
<OGRVRTDataSource>
<OGRVRTLayer name="sorento">
<SrcDataSource>ODBC:@PostgreSQL</SrcDataSource>
<SrcLayer>record</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="Lat" y="Lon"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Here's my file.map:
MAP
IMAGETYPE PNG
EXTENT -92.241493 13.738197 -88.223198 17.815220
SIZE 640 480
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
SYMBOL
NAME 'circle'
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
LAYER
NAME "sorento"
TYPE POINT
CONNECTIONTYPE OGR
work?
STATUS DEFAULT
CLASS
SYMBOL "circle"
SIZE 6
COLOR 255 0 0
END
END
END
The information contained in this communication is confidential, is
intended only for the use of the recipient named above, and may be legally
privileged.
If the reader of this message is not the intended recipient, you are
hereby notified that any dissemination, distribution or copying of this
communication is strictly prohibited.
If you have received this communication in error, please resend this
communication to the sender and delete the original message or any copy
of it from your computer system.
Thank You.
