Label Size error
Mariette mariette.hachey at GEONET-TECH.COM
Mon Dec 19 13:37:07 EST 2005
-----Original Message-----
From: Mariette [mailto:mariette.hachey at geonet-tech.com]
Sent: Monday, December 19, 2005 1:59 PM
To: 'chameleon at lists.maptools.org'
Subject: Label Size error
Greetings,
I am having an issue with Label Font Sizes. You can see in the Map file
excerpt below the two commented out lines.
The minute I allow these lines to go thru I get an internal server error,
otherwise everything is running smoothly.
LAYER
  NAME "Contour"
  STATUS ON
  TYPE LINE
  GROUP "Legend"
  DATA "DT3_CONTOURS"
  CLASSITEM "DXF_LAYER"
  LABELITEM "ELEV"
  CLASS
    NAME "Contour_25m"
    EXPRESSION "LFCI"
    KEYIMAGE "C:\ms4w\apps\Lunenburg\htdocs\images\Con_25.gif"
    STYLE
      COLOR 164 121 22
      SYMBOL "line"
      SIZE 2
    END
    LABEL
      COLOR 164 121 22
      SHADOWCOLOR 218 218 218
      SHADOWSIZE 2 2
      FONT arial-bold
 #     SIZE 8
      POSITION CC
      PARTIALS FALSE
      MINDISTANCE 300
      BUFFER 4
    END
  END
  CLASS
    NAME "Contour_5m"
    EXPRESSION "LFCO"
    KEYIMAGE "C:\ms4w\apps\Lunenburg\htdocs\images\Con_5.gif"
    STYLE
      COLOR 221 168 64
      SYMBOL "line"
      SIZE 1
    END
    LABEL
      COLOR 164 121 22
      SHADOWSIZE 2 2
      FONT arial-bold
#      SIZE 12
      POSITION CC
      PARTIALS FALSE
      MINDISTANCE 300
      BUFFER 4
    END
  END
  PROJECTION
    "init=epsg:2038"
  END
END
I just updated to the most recent Chameleon and ms4w, this problem was not
occuring beforehand.
Would this classifiy as a bug,
Thank You
Mariette Hachey
GIS Technologist
GeoNet Technologies Inc.
Box 22, Suite 211
90 University Ave
Charlottetown, PE
Canada, C1A 4K9
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051219/09ec4bca/attachment.html
