Using class annotation angles
Steve Lime steve.lime at DNR.STATE.MN.US
Mon Dec 19 18:45:32 EST 2005
Let's start with the obvious. Are you sure you are turning that layer on? A working example of that functionality can be found at:
  http://maps.dnr.state.mn.us/mapserver_demos/tests46/text_angle_and_size/test.html
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-259-5473
>>> Don Isgitt <djisgitt at SOUNDENERGY.COM> 12/19/05 3:32 PM >>>
Fawcett, David wrote:
> Try setting a font size with a numeric value, like 16.  You are using
> 'Tiny', which , I suspect would only work with bitmapped fonts.
> David.
Thank you David (and Stephen).
But, unfortunately, changing
size tiny
to
size 8
still does not work (i.e., no text is displayed).
Any more suggestions, anyone, please!
