Mapserver installation
Howard Butler
hobu at IASTATE.EDU
Tue Dec 20 10:36:07 EST 2005
Salah,
Please post messages (and subscribe) to the list. There are many
there with experiences that will help you.
Howard
At 09:14 AM 12/20/2005, salah jubeh wrote:
>Dear Sir;
>Please give 5 minutes from your time , i am trying to install map
>server on winxp machine using Msys and mingu .
>all of the projects --"GDAL,GD,PNG,MAPSERVER" in the same hierarchy
>on c:\projects
>I wrote configuration.sh like this
>./configure --with-gd=../../gdwin32/ \
> --with-png=../../libpng-1.2.8/ \
> --with-zlib=../../zlib/ \
> --with-freetype=../../freetype-2.1.10/ \
> --with-threads
>but it gives this massege
>MapServer Version from map.h: '4.8.0-beta1'
>configure: checking where FreeType 2.x is installed...
>checking for FT_Init_FreeType in -lfreetype... no
> freetype-config or libfreetype cannot be found, possibly
> needed for GD
>configure: checking where Zlib is installed...
>checking for zlibVersion in -lz... no
> Zlib (libz) library cannot be found, possibly needed for GD
>configure: checking where PNG is installed...
>checking for png_init_io in -lpng... no
> PNG (libpng) library cannot be found, possibly needed for GD
>configure: checking whether we should include JPEG support...
>checking for jpeg_read_header in -ljpeg... no
> libjpeg not found. JPEG support not included, possibly needed for GD.
>configure: checking where libXpm is installed...
>checking for XpmFreeXpmImage in -lXpm... no
> XPM (libXpm) library cannot be found, possibly needed for GD
>configure: checking where libiconv is installed...
>checking for iconv_open in -lc... no
>checking for libiconv_open in -liconv... no
> libiconv library cannot be found, possibly needed for GD
>configure: checking for GD 2.0.16 or higher...
>checking for gdFontCacheSetup in -lgd... no
>configure: error: Could not find gd.h or libgd.a/libgd.so in
>/c/projects/mapserv
>er-4.8.0-beta1/../../gdwin32/. Make sure GD 2.0.16 or higher is
>compiled before
> calling configure. You may also get this error if you didn't
> specify the approp
>! riate location for one of GD's dependencies (freetype, libpng,
>libjpeg or libico
>I want to know how to compile it. i have compile it with vc
>enviroment and i just edit the nmake file - the GD lib path.
>Thanks in advance
>Best Regard
>Eng. Salah Al Jubeh
