OGR Virtual
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Dec 21 01:42:29 EST 2005
you might want to put Mapserver and OGR debugging on. Make sure Mapserver is
built with debug info (DEBUG=MSDEBUG when you do mapserv -v)
1) define an environment variable MS_ERRORFILE with a value of stderr (if
you have Apache do it in the httpd.conf with SetEnv, debugging will end up
in the Apache error log file)
2) add CONFIG CPL_DEBUG "ON" to your MAP object in your MAP file, this will
put GDAL/OGR debugging on.
3) add DEBUG ON to your LAYER
Btw, if you have PostgreSQL why not use PostGIS?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Frank Fica
Verzonden: woensdag 21 december 2005 7:10
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] OGR Virtual
Hello,
I've been trying to map a non-spatial postgre table with ogr via ODBC but no
success. There must
be a simple solution to what I'm missing and I haven't been able to figure
it out. My other layers
do render but my Virtual layer doesn't. When I test in ogrinfo I can connect
but when I try to map
in mapserver the image is blank, only my mapinfo layer renders.
Does someone has any suggestions on what I'm missing?
Here are is my ovf file:
<OGRVRTDataSource>
<OGRVRTLayer name="sorento">
<SrcDataSource>ODBC:@PostgreSQL,sorento</SrcDataSource>
<SrcLayer>sorento</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="Lon" y="Lat"/>
</OGRVRTLayer>
</OGRVRTDataSource>
and map file:
MAP
IMAGETYPE PNG
EXTENT -90.760314 14.252771 -90.210352 14.937117
SIZE 640 480
UNITS METERS
SYMBOL
NAME "circle"
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
LAYER
NAME "ciudad"
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "/var/www/html/guatemala/data/ciudad.tab"
STYLEITEM "AUTO"
CLASS
NAME "Ciudad"
END
END
LAYER
NAME "sorento"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "virtual.ovf"
DATA "sorento"
STATUS DEFAULT
CLASS
STYLE
SYMBOL 'circle'
SIZE 30
COLOR 255 0 0
END
END
END
END
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
