SPAM!!!: Re: SPAM!!!: Re: [UMN_MAPSERVER-USERS] SPAM!!!: Re:
[UMN_MAPSERVER-USERS] Shapefile to Mapfile
Sylvain Beorchia
sbeorchia at GI-LEMANS.COM
Wed Dec 21 12:54:07 EST 2005
When i say the shapefiles are yours, i mean that you know what's inside.
And of course there is a software to manage shapefile called ArcView (http://www.esri.com/software/arcgis/arcview/)
(ESRI is the creator of this format)
But you may build your own application using PHP, or the shapelib library.
Sylvain B.
----- Original Message -----
To: Sylvain Beorchia
Sent: Wednesday, December 21, 2005 6:42 PM
Subject: SPAM!!!: Re: [UMN_MAPSERVER-USERS] SPAM!!!: Re: [UMN_MAPSERVER-USERS] Shapefile to Mapfile
Hi ,
Thanks a lot.
As you have mentioned that the shapefiles are ours , by that do you mean that we are supposed to create our own shapefiles. All this while , in order to practise , we have been downloading shapefiles and trying to write map files for them .
So , is there a software to create a shapefile ?
Waiting for your reply
Apeksha
Sylvain Beorchia <sbeorchia at GI-LEMANS.COM> wrote:
"According to our knowledge , a shapefile consists of only one particular
geometric shape."
Yes, right.
" The map file's function is to combine all the shapefiles together n their
segregation into their respective layers. Plz validate this information. "
Yes, if u want.
If you have 3 shapefiles (one for the points, another for the line, and the
last one for the polygons), then you have to describe three layer in your
mapfile. The first one will be of type POINT and the DATA will point to the
shapefile that contains the points...he second layer will be of type LINE
"we want to know as to how do we know what are the contents of a shapefile "
I don't understand what youe mean by that. The shapefiles are yours, so you
know what's inside..., no ?
"We know that shapefile is a combination of .shp , .shx and .dbf files.
However how can we read the data from these files ."
Well , mapserver will display the contents of the shapefiles (ie draw an
image). If you want to read the attributes in the DBF file, then you have to
write some PHP code...for example.
Hope it will help you.
Sylvain Beorchia
Sent: Wednesday, December 21, 2005 1:53 PM
Subject: Re: [UMN_MAPSERVER-USERS] Shapefile to Mapfile
Hey ,
Thanks for ur reply . Could you plz help us further.
geometric shape. The map file's function is to combine all the shapefiles
together n their segregation into their respective layers. Plz validate this
information.
However . we want to know as to how do we know what are the contents of a
shapefile .We have read the online documentation , but are a lil confused.
For eg. for a layer when we declare the ' TYPE ' ( corresponding to a
shapefile ) , how do we know what type does the shapefile contain ?An image
is a collection of various shapefiles . Hence how is the data of each
shapefile interpreted ? We know that shapefile is a combination of .shp ,
.shx and .dbf files. However how can we read the data from these files .
Awaiting your reply .
Sylvain Beorchia wrote:
I think you don't understand the way mapserver work.
You have to write your own mapfile and tell which shapefile you want to
use for a specific layer.
Check the online documentation to see how to declare a new layer for a
shapefile.
Sylvain B.
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Tuesday, December 20, 2005 9:07 PM
Subject: [UMN_MAPSERVER-USERS] Shapefile to Mapfile
If i have a shapefile , how do i convert it into an appropriate
mapfile ? How will i know which layer corresponds to which .shp file ?
Plz help
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Do You Yahoo!?
Do You Yahoo!?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051221/095318d1/attachment.html
