mysql?
Bart van den Eijnden bartvde at XS4ALL.NL
Wed Dec 21 13:29:14 EST 2005
it is a feature called Virtual Spatial Data. In OGR you can connect with
ODBC to MySQL, or you could compile OGR against the MySQL client then
you don't need ODBC. Basically a table with an X and Y column can be
made virtually spatial, or you could have a WKT (or WKB) column with the
geometry in there.
There are the resources:
http://www.gdal.org/ogr/drv_vrt.html
http://www.gdal.org/ogr/drv_odbc.html
http://www.gdal.org/ogr/drv_mysql.html
There is also something native in Mapserver called MyGIS. See:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MySQL
Best regards,
Bart
Paolo Cavallini wrote:
>Hi all.
>I have seen on the home page that MapServer supports MySQL tables via OGR,
>which however does not have support for spatial data. Could someone point out
>a resource to understand this better, or give us a brief overview of MySQL
>support in UMN MS?
>Thanks a lot.
>pc
| Bart van den Eijnden   |
| OSGIS, Open Source GIS |
| http://www.osgis.nl    |
