OGR Virtual
Jani Averbach
javerbach at EXTENDTHEREACH.COM
Wed Dec 21 13:12:13 EST 2005
> -----Original Message-----
> From: UMN MapServer Users List
> Behalf Of Frank Fica
> I've been trying to map a non-spatial postgre table with ogr
> via ODBC but no success.
What is the version of your GDAL? I had very similar problems
and the solution was to upgrade to the CVS-head.
> When I test in ogrinfo I can connect but when I try to map
> in mapserver the image is blank, only my mapinfo layer renders.
> Does someone has any suggestions on what I'm missing?
If you check your postgresql logs, what kind of query do you see there?
a) select * from sorento
or
b) select * from sorento where xxx < lat and lat < xxx and ...
if you see a-type, then I am pretty sure that you have too old version of GDAL.
BR, Jani
