Oracle Woes
Christopher Condit
condit at SDSC.EDU
Thu Dec 22 17:48:45 EST 2005
Hi again-
Yes - I hadn't read that document with enough care. Seems to be working
now, but I (of course) have one more question - the document seems to
indicate that Oracle WFS support is only possible using the OGR driver.
Is this true? I just get the bounding box when I attempt to get WFS
data for my oracle layer.
Thanks,
Chris
-----Original Message-----
Sent: Thursday, December 22, 2005 2:14 PM
To: Christopher Condit
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] Oracle Woes
Hi Christopher,
What operations are you triyng to execute? Just draw a map with the
points? Or any query functions/modes?
For native connection the actual extent is used to create the box
for the operators, in SDO_FILTER and SDO_RELATE. If you don't want to
use this operators you just need to specify USING NONE in your data
defnition.
The link for native connection docs is:
http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
Citando Christopher Condit <condit at sdsc.edu>:
> Hi Fernando
> Thanks very much for your response. I added the USING RELATE
> operator
> and dropped the projection definition from the layer, but still no
> success. Any thoughts? The database already contained lat/lon in
> float
> columns. I create the spatial column with the following SQL:
> alter table SPECIES add (shape mdsys.sdo_geometry);
> update SPECIES
> set shape =
> MDSYS.SDO_GEOMETRY(2001,NULL,MDSYS.SDO_POINT_TYPE(latitude,
> longitude,
> NULL),NULL,NULL)
> where latitude is not null and longitude is not null;
> INSERT INTO USER_SDO_GEOM_METADATA
> VALUES (
> 'SPECIES',
> 'SHAPE',
> MDSYS.SDO_DIM_ARRAY( -- 1440x720 grid
> MDSYS.SDO_DIM_ELEMENT('X', 0, 1440, 0.005),
> MDSYS.SDO_DIM_ELEMENT('Y', 0, 720, 0.005)
> NULL -- SRID
> alter session set sort_area_size = 20000000;
> create index shape_idx on SPECIES(shape) indextype is
> mdsys.spatial_index;
> Thanks,
> Chris
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Fernando Simon
> Sent: Thursday, December 22, 2005 12:54 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Oracle Woes
> Hi Christopher,
> How you added the data in your database? Using shp2sdo, if
> yes,
> after the import did you execute the MIGRATE function?
> If are you trying to do query functions or modes like nquery,
> query, querybyattribute... You need to specify the RELATE operator
> in
> your data definition, in your case:
> DATA "SHAPE FROM (SELECT SHAPE, SCIENTIFICNAME FROM SPECIES
> WHERE
> SCIENTIFICNAME ='Some name') USING RELATE"
> Are you already tried to execute the same operations without
> projection definition?
> Best regards
> Fernando Simon
> Citando Christopher Condit <condit at SDSC.EDU>:
> > Hi All-
> > I'm having tremendous problems getting Oracle 10g Spatial
> support
> > to
> > work with MapServer 4.8 (or 4.6 for that matter).
> > I've tried both the native driver and the OGR driver and shp2img
> > just
> > seems to hang - no error message.
> > This table has about 2 million records, with SDO point geometry
> and
> > a
> > spatial index. The query returns about 100 records.
> > Am I doing something obviously wrong?
> > Ogrinfo does work, however, but I can't find any documentation
> on
> > how to
> > add the select statement to an OGR layer in the mapfile. Does
> > anyone
> > have any idea how to accomplish this?
> > Any help would be greatly appreciated!
> > Here's my layer definition:
> > LAYER #Test of Oracle points
> > NAME oracletest
> > METADATA
> > "wfs_title" "SimpleOracleTest" ## REQUIRED
> > "wfs_geometry_element_name" "shape"
> > "gml_include_items" "all"
> > END
> > TYPE POINT
> > STATUS DEFAULT
> > CONNECTIONTYPE oraclespatial
> > CONNECTION "user/password"
> > # CONNECTIONTYPE ogr
> > # CONNECTION "OCI:user/password"
> > WHERE
> > SCIENTIFICNAME ='Some name')"
> > CLASS
> > COLOR 232 0 0
> > OUTLINECOLOR 0 255 0
> > END
> > DUMP TRUE
> > PROJECTION
> > "init=epsg:4326"
> > END
> > END #end of layer
> > Thanks,
> > Chris
> Univali - Webmail - http://webmail.univali.br
