Raster Analysis and MapServer
Blammo
bob.basques at CI.STPAUL.MN.US
Thu Dec 22 22:24:26 EST 2005
A thought, what about exposing the tool as a Web Service, similar call
to MapServer, only via a WebService. This would help out with the
Thread/Safe issue too as Apache keeps this things generally under
control. Large processes that take some time, might be a problem for
Timeouts. It's just a thought.
I actually thought about this last year when we were first starting out
with our Services architecture at the City.
bobb
Lowell.Filak wrote:
>Martin, Aaron, & others.
>This is good news.
>I have been trying to get processes like this documented to the wiki (before
>the spamming) and to the new site by replying to emails such as these.
>I finally gave up in favor of hiring a contractor to develop a (hopefully)
>uniform scripting language interface between MapScript & GRASS. As a result
>please expect to be contacted by the aforementioned contractor during the
>upcoming feasibility study.
>Lowell
>Martin Hoegh writes:
>>Hi,
>>I also use Grass for backend. I've written a python script using pexpect to
>>start and "drive" a grass session. In this way I can use grass's modules
>>through the script as if I was sitting in front of the terminal. The python
>>script exposes its functions via SOAP, which allows me to call the script
>>with what ever I want - normally php. The down side is that grass is not
>>thread safety, which means you can't start more than one session in a mapset
>>at the time. My script waits in a loop until the previous spawned session
>>ends. This is not good for heavy traffic! After calling grass you can use
>>MapServer to render and display the map, neither directly from the grass
>>database or let grass export the data to a image file.
>>Martin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051222/c7cd9ce6/attachment.html
