Postgis and PostgreSQL Problem
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Dec 23 13:31:38 EST 2005
Frank,
Can you post your layer definition so we can look at that.
Thanks,
-Steve W.
Frank Fica wrote:
> Hi Steve,
> Yes my schema is public.
> Frank
>>Are you using a schema other than public? I think that there are issues
>>with that.
>>-Steve W.
> Frank Fica wrote:
>>Hi,
>>I've been testing the Postgis connection to PostgreSQL in Mapserver. I loaded a Mapinfo file with
>>ogr2ogr. The database seems to have all the required tables and spatial columns. When I test
> my
>>map I get this errors:
>>>From PostgreSQL:
>>ERROR: relation "geometry_columns" does not exist
>>And from my http error_log:
>>msPOSTGISLayerClose -- layerinfo is NULL
>>I do have a geometry_columns table with the appropiate f_table_name and f_geometry_column
>>fields.
>>Any ideas of what I'm missing?
>>Best regards,
>>Frank Fica
