mapserver error with wms layer
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Dec 28 05:58:23 EST 2005
Looking at the source code (mapwmslayer.c), using Mapserver 4.8 you should
be able to use the wms_exceptions_format METADATA at the LAYER level to
override the exception format that Mapserver WMS client sends.
So use:
LAYER
METADATA
wms_exceptions_format "application/vnd.ogc.se_xml"
END
END
Hope this helps.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Xavier Pereta
Verzonden: woensdag 28 december 2005 11:50
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] mapserver error with wms layer
I'm having the same problem with that provider, Lluis.
It seems that Mapserver includes the parameter
"EXCEPTIONS=application/vnd.ogc.se_inimage" at the end of the request, and
the provider doesn't like that parameter.
I have searched the documentation but I haven't found a way to change the
way Mapserver generates the actual requests to the wms servers.
I think that a possible solution would be to make the connection to the wms
provider trhough a HTTP proxy. Then you could make the proxy filter out the
"EXCEPTIONS" parameter from the HTTP requests.
Incidentaly, caching the requests to the wms provider in an HTTP proxy seems
a good idea too, doesn't it?
Have you found any other solution?
Greetings,
Xavier Pereta
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
