JBOX - distance measuring
Richard Greenwood richard.greenwood at GMAIL.COM
Wed Dec 28 09:49:56 EST 2005
salah jubeh <s_jubeh <at> YAHOO.COM> writes:
> Hi Guys     I want to know how this function works - what are these parameters
s, t, and specially c.     also is there is any way to do this without applets.
since the client has to download java VM and many times compatibility problems
occurs.     Thanks in advance.     function measure_handler(name, s, t, n, a)
{// c = 1 / 72dpi / 12inches_per_foot * 1.0003state_plane_scale_factorvar c =
0.0011577546296296; // constantvar f = [scale] * c; // scale factorif ((s>0) ||
(t>0)) {defaultStatus = "This segment = " + s*f + ", Total = " + t*f + ", Number
of vertices = " + n ;}}
jBox returns values in screen pixels.
s is the length of the current segment (in pixels)
t is the total length of all segments
n is the total number of verices (pionts clicked)
a is the area in screen pixels
You must convert the pixel values to real world values with javascript code.
Basically pixel_value * conversion_factor = real_world_distance. The
conversin_factor is the size of the screen pixel in real world units. The 'c' in
the example is a constant used in that caluclation.
HTH,
Richard Greenwood
