projection s57 maps
Peter Huis in 't Veld peterh at IVS90.NL
Wed Dec 28 10:46:51 EST 2005
Hello everyone,
I'm exploring the possibilities of mapserver and I'm a bit stuck on the
visiualisation of ENC / s57  maps
I use the following script:
 SIZE 400 200
 EXTENT  -1000000 195000 365000 7000000
 LEGEND
  STATUS
  POSITION
  TRANSPARANT TRUE
 END
 WEB
   TEMPLATE  "path to global.html"
   IMAGEPATH  "tmp dir"
   IMAGEURL  "dir"
   LOG
 END
LAYER
  NAME s57
  TYPE POLYGON
  STATUS DEFAULT
  CONNECTION TYPE OGR
  CONNECTION "file name"
  PROJECTION
    "proj=tmerc"
   "ellps=WGS84"
  END
  CLASS
       COLOR 247 507 219
       OUTLINECOLOR  100 100 100
   END
END
Requesting this map file using mapserver provides me with in complete
maps. In case I user OpenEv I get a complete visualisation.
I've the following questions:
   - What type of projection and Extent should I use. using ogrinfo
provides me with:
             - extent (5.8333333, 51.833333) - (6.0333333, 51.90000000)
             - WGS84 format indiction ( GEOGCS)
            -  WGS84 , 4326 (AUTHORITY)
  Furthermore, some more generic questions
  - Can I have multple layers using distinct projections? (Shapefile
stored in a Postgis DB and S57 maps)
  - Is there a document to understand the projection type and how to
deal with them?  (I've already downloaded lots of info and I use the
O'reilly WepMapping)
  - Does the gdal component act differently in OpenEv and Mapserver
causing the differences in the result?
I hope these questions can be answered, otherwise I maybe have to be
more specific.
thank is advance
Peter
