mapserver error with wms layer [solved]
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Dec 28 15:08:12 EST 2005
I have added a note at the bottom of the WMS Client Howto since this
seems to be an undocumented feature:
http://mapserver.gis.umn.edu/docs/howto/wms_client/howto_view
Jeff, as the maintainer of the doc, could you make sure it ends up in
the document? Thanks.
Best regards,
Bart
Eijnden, B. van den (Bart) wrote:
>Hi Lluís,
>don't thank me, thank Daniel Morissette who implemented this feature :-)
>Glad to help.
>Best regards,
>Bart
>-----Oorspronkelijk bericht-----
>Van: Lluís Garcia i Mestres [mailto:lluisgarcia at tecnics.org]
>Verzonden: woensdag 28 december 2005 13:55
>Aan: Eijnden, B. van den (Bart); MAPSERVER-USERS at LISTS.UMN.EDU
>Onderwerp: Re: [UMN_MAPSERVER-USERS] mapserver error with wms layer
>[solved]
>Thanks Bart,
>I got it! With the wms_exception_format it works now.
>Àrea de Sistemes d'Informació Geogràfica
>Tecnics.org - Centre tecnològic i solucions integrals
>Plç. Maria Aurèlia Capmany núm.3
>Telf. 973 84 46 23
>25005 Lleida - Catalunya
>----- Original Message -----
>From: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
>To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>Sent: Wednesday, December 28, 2005 11:58 AM
>Subject: Re: [UMN_MAPSERVER-USERS] mapserver error with wms layer
>>Hi,
>>Looking at the source code (mapwmslayer.c), using Mapserver 4.8 you should
>>be able to use the wms_exceptions_format METADATA at the LAYER level to
>>override the exception format that Mapserver WMS client sends.
>>So use:
>>LAYER
>> METADATA
>> wms_exceptions_format "application/vnd.ogc.se_xml"
>> END
>>END
>>Hope this helps.
>>Best regards,
>>Bart
>>Van: UMN MapServer Users List
>>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Xavier Pereta
>>Verzonden: woensdag 28 december 2005 11:50
>>Aan: MAPSERVER-USERS at LISTS.UMN.EDU
>>I'm having the same problem with that provider, Lluis.
>>It seems that Mapserver includes the parameter
>>"EXCEPTIONS=application/vnd.ogc.se_inimage" at the end of the request, and
>>the provider doesn't like that parameter.
>>I have searched the documentation but I haven't found a way to change the
>>way Mapserver generates the actual requests to the wms servers.
>>I think that a possible solution would be to make the connection to the
>>wms
>>provider trhough a HTTP proxy. Then you could make the proxy filter out
>>the
>>"EXCEPTIONS" parameter from the HTTP requests.
>>Incidentaly, caching the requests to the wms provider in an HTTP proxy
>>seems
>>a good idea too, doesn't it?
>>Have you found any other solution?
>>Greetings,
>>Xavier Pereta
>>Disclaimer
>>Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>>uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>>hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>>informeren. Wij adviseren u om bij twijfel over de juistheid of de
>>volledigheid van de mail contact met afzender op te nemen.
>>This message shall not constitute any rights or obligations.
>>This message is intended solely for the addressee.
>>If you have received this message in error, please delete it and
>>notify the sender immediately. When in doubt whether this message
>>is correct or complete, please contact the sender.
>Disclaimer
OSGIS, Open Source GIS
http://www.osgis.nl
