Ok,
this is going to sound like a weird one (Label POSITION Scaling)
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Dec 28 17:52:31 EST 2005
Um, disregard my last reply to this message. I was wrong. My *bad* mapfile was
using no label caching which doesn't take into account symbol size (that could be
considered a bug itself). The URL:
http://maps.dnr.state.mn.us/cgi-bin/mapserv48?map=/usr/local/www/docs_maps/testing/placement/test.map&mode=map
shows that it does take symbol size into account. (One might say too much for
something like a circle symbol.)
I think you'll need to post symbols and mapfile snippets...
Steve
>>> Bob Basques <bob.basques at CI.STPAUL.MN.US> 12/28/05 2:15 PM >>>
All,
Why isn't there a way to define how far out the Label POSITION value
should be, what is the value anyway?
Couldn't a label SCALE value work for something like this? For example,
I' working with a fairly large Symbol and the Labels are drawing over
the top of the symbols. I'm trying to align one symbol to the upper
right, with left justification, and another at the lower Left with right
justification. I tried with the OFFSET parameter, but the negative
numbers seems to be giving MapServer heartache. So I tried it with the
POSTION paramter and while it works as it should, the Labels are still
ending up on top of the Symbols.
With a (pixel) SCALING applied to the POSITION parameter, all would be
well in my own little universe.
I guess this might be an enhancement request. I did a couple of
searches in Bugzilla and didn't see anything related to this.
Possibly with a way to enter the negative number I can get the OFFSET
parameter to help with placement, as using it along side of POSITION
works fine with positive numbers. :c)
bobb
