Ok,
this is going to sound like a weird one (Label POSITION Scaling)
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Dec 28 18:08:23 EST 2005
Which layers are problematic? What mapserver version?
>>> Bob Basques <bob.basques at CI.STPAUL.MN.US> 12/28/05 5:01 PM >>>
No special symbols, just circles for points:
The attached image shows what I get for output.
My Mapfile:
MAP
NAME ORACLE_TEST
SIZE 600 600
EXTENT 540000 135000 600000 175000
# SIZE 800 650
# EXTENT 593133.398829 170094.734526 593893.148973 170712.010326
STATUS ON
DEBUG ON
##UNITS FEET
IMAGETYPE PNG
SYMBOLSET address.symbols
TRANSPARENT TRUE
QUERYMAP
STATUS ON
STYLE SELECTED
END
WEB
QUERYFORMAT "text/xml"
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
TEMPLATE '../../imagemap/monuments_template.html'
END
LAYER
NAME "Address2"
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "OCI:gismo/********@geo"
DATA "ADDRESS_OGR_VIEW"
TYPE POINT
LABELITEM 'HOUSENUMBER'
CLASS
OUTLINECOLOR 0 0 0
LABEL
FORCE TRUE
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SIZE LARGE
#WRAP ' '
POSITION ur
OFFSET 8 8
END
END
MAXSCALE 16000
END
LAYER
NAME "Address2"
STATUS DEFAULT
CONNECTIONTYPE OGR
TYPE POINT
LABELITEM 'STATUS'
CLASS
OUTLINECOLOR 0 0 0
LABEL
FORCE TRUE
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SIZE LARGE
#WRAP ' '
POSITION ll
OFFSET 0 0
END
END
MAXSCALE 16000
END
LAYER
NAME "Address2"
STATUS DEFAULT
# OGR SET
CONNECTIONTYPE OGR
CONNECTION "OCI:gismo/*********@geo"
TYPE POINT
CLASSITEM 'TYPE'
CLASS
EXPRESSION /Primary/
COLOR 0 0 0
SIZE 21
SYMBOL 'circle'
OVERLAYCOLOR 0 255 0
OVERLAYSIZE 15
OVERLAYSYMBOL 'circle'
END
CLASS
EXPRESSION /Secondary/
COLOR 0 0 0
SIZE 35
SYMBOL '3point'
OVERLAYCOLOR 255 255 0
OVERLAYSIZE 19
OVERLAYSYMBOL '3point'
END
CLASS
EXPRESSION /Other/
COLOR 0 0 0
SIZE 35
SYMBOL 'star'
OVERLAYSIZE 19
OVERLAYSYMBOL 'star'
END
CLASS
EXPRESSION /Unofficial-Alias/
COLOR 0 0 0
SIZE 21
SYMBOL 'triangle'
OVERLAYCOLOR 255 0 0
OVERLAYSIZE 12
OVERLAYSYMBOL 'triangle'
END
CLASS
EXPRESSION /Landlocked/
COLOR 0 0 0
SIZE 21
SYMBOL 'diamond'
OVERLAYCOLOR 205 0 0
OVERLAYSIZE 12
OVERLAYSYMBOL 'diamond'
END
HEADER '/pearl/DB/SAINT_PAUL/PUBLIC_WORKS/ADDRESS/address_header.xml'
TEMPLATE '/pearl/DB/SAINT_PAUL/PUBLIC_WORKS/ADDRESS/address_record.xml'
FOOTER '/pearl/DB/SAINT_PAUL/PUBLIC_WORKS/ADDRESS/address_footer.xml'
MAXSCALE 16000
END ##LAYER
END
bobb
Steve Lime wrote:
>There looks to be a bug someplace. *argh*
> See http://maps.dnr.state.mn.us/cgi-bin/mapserv48?map=/usr/local/www/docs_maps/testing/placement/test.map&mode=map
>You shouldn't need to manually compute any offset. The code is written to take into account
>the symbol size when computing label position. The labels are offset by 1/2 the marker size. (The
>user defined offset is applied after that.) I can only guess that there is something busted in the
>size computation function. I'll check on that.
>Steve
>>>>Bob Basques <bob.basques at CI.STPAUL.MN.US> 12/28/05 2:15 PM >>>
>All,
>Why isn't there a way to define how far out the Label POSITION value
>should be, what is the value anyway?
>Couldn't a label SCALE value work for something like this? For example,
>I' working with a fairly large Symbol and the Labels are drawing over
>the top of the symbols. I'm trying to align one symbol to the upper
>right, with left justification, and another at the lower Left with right
>justification. I tried with the OFFSET parameter, but the negative
>numbers seems to be giving MapServer heartache. So I tried it with the
>POSTION paramter and while it works as it should, the Labels are still
>ending up on top of the Symbols.
>With a (pixel) SCALING applied to the POSITION parameter, all would be
>well in my own little universe.
>I guess this might be an enhancement request. I did a couple of
>searches in Bugzilla and didn't see anything related to this.
>Possibly with a way to enter the negative number I can get the OFFSET
>parameter to help with placement, as using it along side of POSITION
>works fine with positive numbers. :c)
>bobb
