Negative numbers in a Label OFFSET, how?
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Wed Dec 28 19:20:51 EST 2005
Hi Steve,
Have you tried this using ANGLE AUTO on LINE type data?
Are the X/Y offsets in image coordinate system OR in the more useful
rotated label coordinate system? ;)
-Steve
Steve Lime wrote:
> URL should be:
> http://maps.dnr.state.mn.us/cgi-bin/mapserv48?map=/usr/local/www/docs_maps/testing/offset/test.map&mode=map
>>>> Steve Lime <steve.lime at DNR.STATE.MN.US> 12/28/05 4:30 PM >>>
> That shouldn't be the case. Offsets are applied regardless of sign.
> Here's a test case:
> http://maps/cgi-bin/mapserv48?map=/usr/local/www/docs_maps/testing/offset/test.map&mode=map
> Steve
>>>> Bob Basques <bob.basques at CI.STPAUL.MN.US> 12/28/05 1:44 PM >>>
> All,
> My OFFSET values are being interpreted as Positive even though they
> are negative numbers.
> Actually only the "y" value is doing this, the X value seems to be
> working just fine.
> Do I need to quote the "-" signs or something in the MAP file?
> I didn't see anything in the Reference page about it.
> bobb
