Using MapServer as a C/C++ library
Norman Vine
nhv at CAPE.COM
Thu Dec 29 10:01:42 EST 2005
Brian Peschel writes:
> So I am curious about using MapServer inside an existing C++ program. A
> previous query about this suggested I shell out to the OS and call shp2image
> to create the image which I could then read in. Shelling to the OS is not
> my prefered way of doing anything (there are limitations in the C system()
> call I would prefer to avoid). So, I would rather use MapServer as a
> library call.
if you can do everything you want with shp2img then ....
it is easy enough to change the main() to shp2img()
and call that with an appropriate char *[] that your
program creates dynamically
HTH
Norman
