Sort of MapServer related . . Stacked,
or coincident points . . .
Bob Basques
bob.basques at CI.STPAUL.MN.US
Thu Dec 29 11:37:44 EST 2005
Dylan Keon wrote:
>1) jitter the points by introducing a small amount of random error
>into the coordinates (only works well when zoomed in pretty far).
>2) plot a single point for each research site, with data for multiple
>specimens contained in the attributes for that point.
>3) render a single point of one color where multiple specimens were
>collected at a site, and another color where a single specimen was
>collected.
>In my case option 2 worked out pretty well. However, your data are
>quite different and I wasn't doing imagemaps. Also, my data were
>selected and rendered dynamically based upon the user's query. You
>mentioned you can't separate the points easily - is your address
>dataset stored in a database,
It's not so much that I can't seperate them, as it is the need to keep
them together for business reasons.
There is at least a "primary" (tax Owner) address in every case, along
with possible secondary addresses in the cases of Duplexes and Apt.
Buildings, etc. All Addresses need to be viewable, even if I seperate
out the Primary, there would still be instances of secondary stacked
points. I'm still researching this at this point to gather options.
The data is all in a Oracle DB
bobb
> or is it more static (shapefile)?=20
>Anyway, maybe this will give you some ideas. HTH.
>Dylan
