installation problems [was Re: Example Maps]
Nicole Faust n_faust at INFORMATIK.UNI-KL.DE
Tue Feb 1 06:29:44 EST 2005
Hello,
> Did you succeed to compile as a CGI. Nothing is missing in your
> configuration. You may want to add
> --with-regex=system
> But this does not prevent the CGI to compile. The cgi executable is
> supposed to be in sapi/cgi/
I added the option --with-regex=system but it is not listed in the options
by phpinfo(), strange...
It seemed that the compilation was successfull.
And I found the cgi executable in the mentioned directory.
> if you do a simle test.php page:
> <?php
> dl("php_mapscript_40.so");
> phpinfo();
> Does the phpinfo page show the loaded mapscript extension?
I made a file named php_test.php4 with the commands shown above.
But when I try to execute the php_test.php4 file I got these
error messages and afterwards the output of phpinfo():
Notice: Constant MS_TRUE already defined in
/home/n_faust/software/projekt/htdocs/php_test.php4 on line 2
Notice: Constant MS_FALSE already defined in
Notice: Constant MS_ON already defined in
Notice: Constant MS_OFF already defined in
Notice: Constant MS_YES already defined in
Notice: Constant MS_NO already defined in
Notice: Constant MS_INCHES already defined in
Notice: Constant MS_FEET already defined in
Notice: Constant MS_MILES already defined in
Notice: Constant MS_METERS already defined in
Notice: Constant MS_KILOMETERS already defined in
Notice: Constant MS_DD already defined in
Notice: Constant MS_PIXELS already defined in
Notice: Constant MS_LAYER_POINT already defined in
Notice: Constant MS_LAYER_LINE already defined in
Notice: Constant MS_LAYER_POLYGON already defined in
Notice: Constant MS_LAYER_RASTER already defined in
Notice: Constant MS_LAYER_ANNOTATION already defined in
Notice: Constant MS_LAYER_QUERY already defined in
Notice: Constant MS_LAYER_CIRCLE already defined in
Notice: Constant MS_LAYER_TILEINDEX already defined in
Notice: Constant MS_DEFAULT already defined in
Notice: Constant MS_EMBED already defined in
Notice: Constant MS_DELETE already defined in
Notice: Constant MS_TRUETYPE already defined in
Notice: Constant MS_BITMAP already defined in
Notice: Constant MS_TINY already defined in
Notice: Constant MS_SMALL already defined in
Notice: Constant MS_MEDIUM already defined in
Notice: Constant MS_LARGE already defined in
Notice: Constant MS_GIANT already defined in
Notice: Constant MS_UL already defined in
Notice: Constant MS_LR already defined in
Notice: Constant MS_UR already defined in
Notice: Constant MS_LL already defined in
Notice: Constant MS_CR already defined in
Notice: Constant MS_CL already defined in
Notice: Constant MS_UC already defined in
Notice: Constant MS_LC already defined in
Notice: Constant MS_CC already defined in
Notice: Constant MS_AUTO already defined in
Notice: Constant MS_XY already defined in
Notice: Constant MS_SHAPE_POINT already defined in
Notice: Constant MS_SHAPE_LINE already defined in
Notice: Constant MS_SHAPE_POLYGON already defined in
Notice: Constant MS_SHAPE_NULL already defined in
Notice: Constant MS_SHP_POINT already defined in
Notice: Constant MS_SHP_ARC already defined in
Notice: Constant MS_SHP_POLYGON already defined in
Notice: Constant MS_SHP_MULTIPOINT already defined in
Notice: Constant MS_SHP_POINTM already defined in
Notice: Constant MS_SHP_ARCM already defined in
Notice: Constant MS_SHP_POLYGONM already defined in
Notice: Constant MS_SHP_MULTIPOINTM already defined in
Notice: Constant SHP_POINT already defined in
Notice: Constant SHP_ARC already defined in
Notice: Constant SHP_POLYGON already defined in
Notice: Constant SHP_MULTIPOINT already defined in
Notice: Constant SHP_POINTM already defined in
Notice: Constant SHP_ARCM already defined in
Notice: Constant SHP_POLYGONM already defined in
Notice: Constant SHP_MULTIPOINTM already defined in
Notice: Constant MS_SINGLE already defined in
Notice: Constant MS_MULTIPLE already defined in
Notice: Constant MS_INLINE already defined in
Notice: Constant MS_SHAPEFILE already defined in
Notice: Constant MS_TILED_SHAPEFILE already defined in
Notice: Constant MS_SDE already defined in
Notice: Constant MS_OGR already defined in
Notice: Constant MS_POSTGIS already defined in
Notice: Constant MS_MYGIS already defined in
Notice: Constant MS_WMS already defined in
Notice: Constant MS_WFS already defined in
Notice: Constant MS_ORACLESPATIAL already defined in
Notice: Constant MS_GRATICULE already defined in
Notice: Constant MS_NORMAL already defined in
Notice: Constant MS_HILITE already defined in
Notice: Constant MS_SELECTED already defined in
Notice: Constant MS_SUCCESS already defined in
Notice: Constant MS_FAILURE already defined in
Notice: Constant MS_DONE already defined in
Notice: Constant MS_NOERR already defined in
Notice: Constant MS_IOERR already defined in
Notice: Constant MS_MEMERR already defined in
Notice: Constant MS_TYPEERR already defined in
Notice: Constant MS_SYMERR already defined in
Notice: Constant MS_REGEXERR already defined in
Notice: Constant MS_TTFERR already defined in
Notice: Constant MS_DBFERR already defined in
Notice: Constant MS_GDERR already defined in
Notice: Constant MS_IDENTERR already defined in
Notice: Constant MS_EOFERR already defined in
Notice: Constant MS_PROJERR already defined in
Notice: Constant MS_MISCERR already defined in
Notice: Constant MS_CGIERR already defined in
Notice: Constant MS_WEBERR already defined in
Notice: Constant MS_IMGERR already defined in
Notice: Constant MS_HASHERR already defined in
Notice: Constant MS_JOINERR already defined in
Notice: Constant MS_NOTFOUND already defined in
Notice: Constant MS_SHPERR already defined in
Notice: Constant MS_PARSEERR already defined in
Notice: Constant MS_SDEERR already defined in
Notice: Constant MS_OGRERR already defined in
Notice: Constant MS_QUERYERR already defined in
Notice: Constant MS_WMSERR already defined in
Notice: Constant MS_WMSCONNERR already defined in
Notice: Constant MS_ORACLESPATIALERR already defined in
Notice: Constant MS_WFSERR already defined in
Notice: Constant MS_WFSCONNERR already defined in
Notice: Constant MS_MAPCONTEXTERR already defined in
Notice: Constant MS_HTTPERR already defined in
Notice: Constant MS_SYMBOL_SIMPLE already defined in
Notice: Constant MS_SYMBOL_VECTOR already defined in
Notice: Constant MS_SYMBOL_ELLIPSE already defined in
Notice: Constant MS_SYMBOL_PIXMAP already defined in
Notice: Constant MS_SYMBOL_TRUETYPE already defined in
Notice: Constant MS_SYMBOL_CARTOLINE already defined in
Warning: Function registration failed - duplicate name - ms_getversion in
Warning: Function registration failed - duplicate name - ms_newmapobj in
Warning: Function registration failed - duplicate name - ms_newlayerobj in
Warning: Function registration failed - duplicate name - ms_newclassobj in
Warning: Function registration failed - duplicate name - ms_newpointobj in
Warning: Function registration failed - duplicate name - ms_newlineobj in
Warning: Function registration failed - duplicate name - ms_newshapeobj in
ms_newshapefileobj in /home/n_faust/software/projekt/htdocs/php_test.php4
on line 2
Warning: Function registration failed - duplicate name - ms_newrectobj in
Warning: Function registration failed - duplicate name - ms_getcwd in
Warning: Function registration failed - duplicate name - ms_getpid in
Warning: Function registration failed - duplicate name - ms_getscale in
ms_newprojectionobj in /home/n_faust/software/projekt/htdocs/php_test.php4
on line 2
Warning: Function registration failed - duplicate name - ms_tokenizemap in
Warning: Function registration failed - duplicate name - ms_newstyleobj in
Warning: Function registration failed - duplicate name - ms_newgridobj in
Warning: Function registration failed - duplicate name - ms_geterrorobj in
Warning: Function registration failed - duplicate name - ms_reseterrorlist
in /home/n_faust/software/projekt/htdocs/php_test.php4 on line 2
Warning: Function registration failed - duplicate name - ms_newsymbolobj
Warning: MapScript: Unable to register functions, unable to load in
Unknown on line 0
(I added the .html file, so you can take a look at it.)
In the MapScript section this can be found:
MapServer Version
MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
PHP MapScript Version
($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43
Regards,
   Nicole
<br />
<b>Notice</b>:  Constant MS_TRUE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_FALSE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_ON already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_OFF already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_YES already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_NO already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_INCHES already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_FEET already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_MILES already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_METERS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_KILOMETERS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_DD already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_PIXELS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_POINT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_LINE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_POLYGON already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_RASTER already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_ANNOTATION already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_QUERY already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_CIRCLE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LAYER_TILEINDEX already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_DEFAULT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_EMBED already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_DELETE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_TRUETYPE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_BITMAP already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_TINY already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SMALL already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_MEDIUM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LARGE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_GIANT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_UL already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_UR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LL already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_CR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_CL already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_UC already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_LC already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_CC already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_AUTO already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_XY already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHAPE_POINT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHAPE_LINE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHAPE_POLYGON already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHAPE_NULL already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_POINT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_ARC already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_POLYGON already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_MULTIPOINT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_POINTM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_ARCM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_POLYGONM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHP_MULTIPOINTM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_POINT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_ARC already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_POLYGON already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_MULTIPOINT already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_POINTM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_ARCM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_POLYGONM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant SHP_MULTIPOINTM already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SINGLE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_MULTIPLE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_INLINE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHAPEFILE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_TILED_SHAPEFILE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SDE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_OGR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_POSTGIS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_MYGIS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_WMS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_WFS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_ORACLESPATIAL already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_GRATICULE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_NORMAL already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_HILITE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SELECTED already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SUCCESS already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_FAILURE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_DONE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_NOERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_IOERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_MEMERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_TYPEERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SYMERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_REGEXERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_TTFERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_DBFERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_GDERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_IDENTERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_EOFERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_PROJERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_MISCERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_CGIERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_WEBERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_IMGERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_HASHERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_JOINERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_NOTFOUND already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SHPERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_PARSEERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SDEERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_OGRERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_QUERYERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_WMSERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_WMSCONNERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_ORACLESPATIALERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_WFSERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_WFSCONNERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_MAPCONTEXTERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_HTTPERR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SYMBOL_SIMPLE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SYMBOL_VECTOR already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SYMBOL_ELLIPSE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SYMBOL_PIXMAP already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SYMBOL_TRUETYPE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Notice</b>:  Constant MS_SYMBOL_CARTOLINE already defined in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_getversion in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newmapobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newlayerobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newclassobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newpointobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newlineobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newshapeobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newshapefileobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newrectobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_getcwd in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_getpid in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_getscale in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newprojectionobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_tokenizemap in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newstyleobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newgridobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_geterrorobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_reseterrorlist in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  Function registration failed - duplicate name - ms_newsymbolobj in <b>/home/n_faust/software/projekt/htdocs/php_test.php4</b> on line <b>2</b><br />
<br />
<b>Warning</b>:  MapScript:  Unable to register functions, unable to load in <b>Unknown</b> on line <b>0</b><br />
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "DTD/xhtml1-transitional.dtd">
<html><head>
<style type="text/css"><!--
body {background-color: #ffffff; color: #000000;}
body, td, th, h1, h2 {font-family: sans-serif;}
pre {margin: 0px; font-family: monospace;}
a:link {color: #000099; text-decoration: none; background-color: #ffffff;}
a:hover {text-decoration: underline;}
table {border-collapse: collapse;}
.center {text-align: center;}
.center table { margin-left: auto; margin-right: auto; text-align: left;}
.center th { text-align: center !important; }
td, th { border: 1px solid #000000; font-size: 75%; vertical-align: baseline;}
h1 {font-size: 150%;}
h2 {font-size: 125%;}
.p {text-align: left;}
.e {background-color: #ccccff; font-weight: bold; color: #000000;}
.h {background-color: #9999cc; font-weight: bold; color: #000000;}
.v {background-color: #cccccc; color: #000000;}
i {color: #666666; background-color: #cccccc;}
img {float: right; border: 0px;}
hr {width: 600px; background-color: #cccccc; border: 0px; height: 1px; color: #000000;}
//--></style>
<title>phpinfo()</title></head>
<body><div class="center">
<table border="0" cellpadding="3" width="600">
<tr class="h"><td>
<a href="http://www.php.net/"><img border="0" src="/php_test.php4?=PHPE9568F34-D428-11d2-A769-00AA001ACF42" alt="PHP Logo" /></a><h1 class="p">PHP Version 4.3.10</h1>
</td></tr>
</table><br />
<tr><td class="e">System </td><td class="v">Linux rockster 2.6.8-24.11-smp #1 SMP Fri Jan 14 13:01:26 UTC 2005 i686 </td></tr>
<tr><td class="e">Build Date </td><td class="v">Jan 24 2005 11:02:53 </td></tr>
<tr><td class="e">Configure Command </td><td class="v"> './configure' '--with-gd=/home/n_faust/software/projekt' '--with-pgsql=/home/n_faust/software/projekt' '--enable-force-cgi-redirect' '--enable-fastcgi' '--prefix=/home/n_faust/software/projekt' </td></tr>
<tr><td class="e">Server API </td><td class="v">CGI/FastCGI </td></tr>
<tr><td class="e">Virtual Directory Support </td><td class="v">disabled </td></tr>
<tr><td class="e">Configuration File (php.ini) Path </td><td class="v">/home/n_faust/software/projekt/lib/php.ini </td></tr>
<tr><td class="e">PHP API </td><td class="v">20020918 </td></tr>
<tr><td class="e">PHP Extension </td><td class="v">20020429 </td></tr>
<tr><td class="e">Zend Extension </td><td class="v">20021010 </td></tr>
<tr><td class="e">Debug Build </td><td class="v">no </td></tr>
<tr><td class="e">Thread Safety </td><td class="v">disabled </td></tr>
<tr><td class="e">Registered PHP Streams </td><td class="v">php, http, ftp   </td></tr>
</table><br />
<tr class="v"><td>
<a href="http://www.zend.com/"><img border="0" src="/php_test.php4?=PHPE9568F35-D428-11d2-A769-00AA001ACF42" alt="Zend logo" /></a>
This program makes use of the Zend Scripting Language Engine:<br />Zend Engine v1.3.0, Copyright (c) 1998-2004 Zend Technologies
</td></tr>
</table><br />
<hr />
<h1><a href="/php_test.php4?=PHPB8B5F2A0-3C92-11d3-A3A9-4C7B08C10000">PHP Credits</a></h1>
<hr />
<h1>Configuration</h1>
<h2>PHP Core</h2>
<tr class="h"><th>Directive</th><th>Local Value</th><th>Master Value</th></tr>
<tr><td class="e">allow_call_time_pass_reference</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">allow_url_fopen</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">always_populate_raw_post_data</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">arg_separator.input</td><td class="v">&amp;</td><td class="v">&amp;</td></tr>
<tr><td class="e">arg_separator.output</td><td class="v">&amp;</td><td class="v">&amp;</td></tr>
<tr><td class="e">asp_tags</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">auto_append_file</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">auto_prepend_file</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">browscap</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">default_charset</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">default_mimetype</td><td class="v">text/html</td><td class="v">text/html</td></tr>
<tr><td class="e">define_syslog_variables</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">disable_classes</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">disable_functions</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">display_errors</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">display_startup_errors</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">doc_root</td><td class="v">/home/n_faust/software/projekt/htdocs</td><td class="v">/home/n_faust/software/projekt/htdocs</td></tr>
<tr><td class="e">docref_ext</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">docref_root</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">enable_dl</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">error_append_string</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">error_log</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">error_prepend_string</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">error_reporting</td><td class="v">2047</td><td class="v">2047</td></tr>
<tr><td class="e">expose_php</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">extension_dir</td><td class="v">/home/n_faust/software/projekt/lib/php</td><td class="v">/home/n_faust/software/projekt/lib/php</td></tr>
<tr><td class="e">file_uploads</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">gpc_order</td><td class="v">GPC</td><td class="v">GPC</td></tr>
<tr><td class="e">highlight.bg</td><td class="v"><font style="color: #FFFFFF">#FFFFFF</font></td><td class="v"><font style="color: #FFFFFF">#FFFFFF</font></td></tr>
<tr><td class="e">highlight.comment</td><td class="v"><font style="color: #FF8000">#FF8000</font></td><td class="v"><font style="color: #FF8000">#FF8000</font></td></tr>
<tr><td class="e">highlight.default</td><td class="v"><font style="color: #0000BB">#0000BB</font></td><td class="v"><font style="color: #0000BB">#0000BB</font></td></tr>
<tr><td class="e">highlight.html</td><td class="v"><font style="color: #000000">#000000</font></td><td class="v"><font style="color: #000000">#000000</font></td></tr>
<tr><td class="e">highlight.keyword</td><td class="v"><font style="color: #007700">#007700</font></td><td class="v"><font style="color: #007700">#007700</font></td></tr>
<tr><td class="e">highlight.string</td><td class="v"><font style="color: #DD0000">#DD0000</font></td><td class="v"><font style="color: #DD0000">#DD0000</font></td></tr>
<tr><td class="e">html_errors</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">ignore_repeated_errors</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">ignore_repeated_source</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">ignore_user_abort</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">implicit_flush</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">include_path</td><td class="v">.:/home/n_faust/software/projekt/lib/php</td><td class="v">.:/home/n_faust/software/projekt/lib/php</td></tr>
<tr><td class="e">log_errors</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">log_errors_max_len</td><td class="v">1024</td><td class="v">1024</td></tr>
<tr><td class="e">magic_quotes_gpc</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">magic_quotes_runtime</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">magic_quotes_sybase</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">max_execution_time</td><td class="v">30</td><td class="v">30</td></tr>
<tr><td class="e">max_input_time</td><td class="v">60</td><td class="v">60</td></tr>
<tr><td class="e">open_basedir</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">output_buffering</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">output_handler</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">post_max_size</td><td class="v">8M</td><td class="v">8M</td></tr>
<tr><td class="e">precision</td><td class="v">12</td><td class="v">12</td></tr>
<tr><td class="e">register_argc_argv</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">register_globals</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">report_memleaks</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">safe_mode</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">safe_mode_exec_dir</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">safe_mode_gid</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">safe_mode_include_dir</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">sendmail_from</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">sendmail_path</td><td class="v">/usr/sbin/sendmail -t -i </td><td class="v">/usr/sbin/sendmail -t -i </td></tr>
<tr><td class="e">serialize_precision</td><td class="v">100</td><td class="v">100</td></tr>
<tr><td class="e">short_open_tag</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">SMTP</td><td class="v">localhost</td><td class="v">localhost</td></tr>
<tr><td class="e">smtp_port</td><td class="v">25</td><td class="v">25</td></tr>
<tr><td class="e">sql.safe_mode</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">track_errors</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">unserialize_callback_func</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">upload_max_filesize</td><td class="v">20M</td><td class="v">20M</td></tr>
<tr><td class="e">upload_tmp_dir</td><td class="v">/home/n_faust/</td><td class="v">/home/n_faust/</td></tr>
<tr><td class="e">user_dir</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">variables_order</td><td class="v">EGPCS</td><td class="v">EGPCS</td></tr>
<tr><td class="e">xmlrpc_error_number</td><td class="v">0</td><td class="v">0</td></tr>
<tr><td class="e">xmlrpc_errors</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">y2k_compliance</td><td class="v">On</td><td class="v">On</td></tr>
</table><br />
<h2><a name="module_MapScript">MapScript</a></h2>
<tr><td class="e">MapServer Version </td><td class="v">MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE </td></tr>
<tr><td class="e">PHP MapScript Version </td><td class="v">($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43 $) </td></tr>
</table><br />
<h2><a name="module_ctype">ctype</a></h2>
<tr><td class="e">ctype functions </td><td class="v">enabled </td></tr>
</table><br />
<h2><a name="module_gd">gd</a></h2>
<tr><td class="e">GD Support </td><td class="v">enabled </td></tr>
<tr><td class="e">GD Version </td><td class="v">2.0 or higher </td></tr>
<tr><td class="e">GIF Read Support </td><td class="v">enabled </td></tr>
<tr><td class="e">GIF Create Support </td><td class="v">enabled </td></tr>
<tr><td class="e">JPG Support </td><td class="v">enabled </td></tr>
<tr><td class="e">PNG Support </td><td class="v">enabled </td></tr>
<tr><td class="e">WBMP Support </td><td class="v">enabled </td></tr>
</table><br />
<h2><a name="module_mysql">mysql</a></h2>
<tr class="h"><th>MySQL Support</th><th>enabled</th></tr>
<tr><td class="e">Active Persistent Links </td><td class="v">0 </td></tr>
<tr><td class="e">Active Links </td><td class="v">0 </td></tr>
<tr><td class="e">Client API version </td><td class="v">3.23.49 </td></tr>
<tr><td class="e">MYSQL_MODULE_TYPE </td><td class="v">builtin </td></tr>
<tr><td class="e">MYSQL_SOCKET </td><td class="v">/tmp/mysql.sock </td></tr>
<tr><td class="e">MYSQL_INCLUDE </td><td class="v"><i>no value</i> </td></tr>
<tr><td class="e">MYSQL_LIBS </td><td class="v"><i>no value</i> </td></tr>
</table><br />
<tr><td class="e">mysql.allow_persistent</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">mysql.connect_timeout</td><td class="v">60</td><td class="v">60</td></tr>
<tr><td class="e">mysql.default_host</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">mysql.default_password</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">mysql.default_port</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">mysql.default_socket</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">mysql.default_user</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">mysql.max_links</td><td class="v">Unlimited</td><td class="v">Unlimited</td></tr>
<tr><td class="e">mysql.max_persistent</td><td class="v">Unlimited</td><td class="v">Unlimited</td></tr>
<tr><td class="e">mysql.trace_mode</td><td class="v">Off</td><td class="v">Off</td></tr>
</table><br />
<h2><a name="module_overload">overload</a></h2>
<tr><td class="e">User-Space Object Overloading Support </td><td class="v">enabled </td></tr>
</table><br />
<h2><a name="module_pcre">pcre</a></h2>
<tr><td class="e">PCRE (Perl Compatible Regular Expressions) Support </td><td class="v">enabled </td></tr>
<tr><td class="e">PCRE Library Version </td><td class="v">4.5 01-December-2003 </td></tr>
</table><br />
<h2><a name="module_pgsql">pgsql</a></h2>
<tr class="h"><th>PostgreSQL Support</th><th>enabled</th></tr>
<tr><td class="e">PostgreSQL(libpq) Version </td><td class="v">7.4.5 </td></tr>
<tr><td class="e">Multibyte character support </td><td class="v">enabled </td></tr>
<tr><td class="e">SSL support </td><td class="v">disabled </td></tr>
</table><br />
<tr><td class="e">pgsql.allow_persistent</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">pgsql.auto_reset_persistent</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">pgsql.ignore_notice</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">pgsql.log_notice</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">pgsql.max_links</td><td class="v">Unlimited</td><td class="v">Unlimited</td></tr>
<tr><td class="e">pgsql.max_persistent</td><td class="v">Unlimited</td><td class="v">Unlimited</td></tr>
</table><br />
<h2><a name="module_posix">posix</a></h2>
<tr><td class="e">Revision </td><td class="v">$Revision: 1.51.2.2 $ </td></tr>
</table><br />
<h2><a name="module_session">session</a></h2>
<tr><td class="e">Session Support </td><td class="v">enabled </td></tr>
<tr><td class="e">Registered save handlers </td><td class="v">files user  </td></tr>
</table><br />
<tr><td class="e">session.auto_start</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">session.bug_compat_42</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">session.bug_compat_warn</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">session.cache_expire</td><td class="v">180</td><td class="v">180</td></tr>
<tr><td class="e">session.cache_limiter</td><td class="v">nocache</td><td class="v">nocache</td></tr>
<tr><td class="e">session.cookie_domain</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">session.cookie_lifetime</td><td class="v">0</td><td class="v">0</td></tr>
<tr><td class="e">session.cookie_path</td><td class="v">/</td><td class="v">/</td></tr>
<tr><td class="e">session.cookie_secure</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">session.entropy_file</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">session.entropy_length</td><td class="v">0</td><td class="v">0</td></tr>
<tr><td class="e">session.gc_divisor</td><td class="v">100</td><td class="v">100</td></tr>
<tr><td class="e">session.gc_maxlifetime</td><td class="v">1440</td><td class="v">1440</td></tr>
<tr><td class="e">session.gc_probability</td><td class="v">1</td><td class="v">1</td></tr>
<tr><td class="e">session.name</td><td class="v">PHPSESSID</td><td class="v">PHPSESSID</td></tr>
<tr><td class="e">session.referer_check</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">session.save_handler</td><td class="v">files</td><td class="v">files</td></tr>
<tr><td class="e">session.save_path</td><td class="v">/tmp</td><td class="v">/tmp</td></tr>
<tr><td class="e">session.serialize_handler</td><td class="v">php</td><td class="v">php</td></tr>
<tr><td class="e">session.use_cookies</td><td class="v">On</td><td class="v">On</td></tr>
<tr><td class="e">session.use_only_cookies</td><td class="v">Off</td><td class="v">Off</td></tr>
<tr><td class="e">session.use_trans_sid</td><td class="v">Off</td><td class="v">Off</td></tr>
</table><br />
<h2><a name="module_standard">standard</a></h2>
<tr><td class="e">Regex Library </td><td class="v">Bundled library enabled </td></tr>
<tr><td class="e">Dynamic Library Support </td><td class="v">enabled </td></tr>
<tr><td class="e">Path to sendmail </td><td class="v">/usr/sbin/sendmail -t -i  </td></tr>
</table><br />
<tr><td class="e">assert.active</td><td class="v">1</td><td class="v">1</td></tr>
<tr><td class="e">assert.bail</td><td class="v">0</td><td class="v">0</td></tr>
<tr><td class="e">assert.callback</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">assert.quiet_eval</td><td class="v">0</td><td class="v">0</td></tr>
<tr><td class="e">assert.warning</td><td class="v">1</td><td class="v">1</td></tr>
<tr><td class="e">auto_detect_line_endings</td><td class="v">0</td><td class="v">0</td></tr>
<tr><td class="e">default_socket_timeout</td><td class="v">60</td><td class="v">60</td></tr>
<tr><td class="e">safe_mode_allowed_env_vars</td><td class="v">PHP_</td><td class="v">PHP_</td></tr>
<tr><td class="e">safe_mode_protected_env_vars</td><td class="v">LD_LIBRARY_PATH</td><td class="v">LD_LIBRARY_PATH</td></tr>
<tr><td class="e">url_rewriter.tags</td><td class="v">a=href,area=href,frame=src,input=src,form=,fieldset=</td><td class="v">a=href,area=href,frame=src,input=src,form=,fieldset=</td></tr>
<tr><td class="e">user_agent</td><td class="v"><i>no value</i></td><td class="v"><i>no value</i></td></tr>
</table><br />
<h2><a name="module_tokenizer">tokenizer</a></h2>
<tr><td class="e">Tokenizer Support </td><td class="v">enabled </td></tr>
</table><br />
<h2><a name="module_xml">xml</a></h2>
<tr><td class="e">XML Support </td><td class="v">active </td></tr>
<tr><td class="e">XML Namespace Support </td><td class="v">active </td></tr>
<tr><td class="e">EXPAT Version </td><td class="v">1.95.6 </td></tr>
</table><br />
<h2>Additional Modules</h2>
<tr class="h"><th>Module Name</th></tr>
</table><br />
<h2>Environment</h2>
<tr class="h"><th>Variable</th><th>Value</th></tr>
<tr><td class="e">REDIRECT_STATUS </td><td class="v">200 </td></tr>
<tr><td class="e">LD_LIBRARY_PATH </td><td class="v">/home/n_faust/software/projekt/lib </td></tr>
<tr><td class="e">HTTP_ACCEPT </td><td class="v">image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, */* </td></tr>
<tr><td class="e">HTTP_ACCEPT_LANGUAGE </td><td class="v">de </td></tr>
<tr><td class="e">HTTP_ACCEPT_ENCODING </td><td class="v">gzip, deflate </td></tr>
<tr><td class="e">HTTP_USER_AGENT </td><td class="v">Mozilla/4.0 (compatible; MSIE 6.0; Windows 98) </td></tr>
<tr><td class="e">HTTP_HOST </td><td class="v">rockster.informatik.uni-kl.de:8081 </td></tr>
<tr><td class="e">HTTP_CONNECTION </td><td class="v">Keep-Alive </td></tr>
<tr><td class="e">PATH </td><td class="v">/opt/kde3/bin:/opt/gnome/bin:/usr/games:/usr/bin/X11:/usr/bin:/bin:/usr/local/bin:/home/n_faust/software/postgresql-7.4.5/bin:/opt2/jdk-1.4/bin:. </td></tr>
<tr><td class="e">SERVER_SIGNATURE </td><td class="v">&lt;address&gt;Apache/2.0.52 (Unix) Server at rockster.informatik.uni-kl.de Port 8081&lt;/address&gt;
 </td></tr>
<tr><td class="e">SERVER_SOFTWARE </td><td class="v">Apache/2.0.52 (Unix) </td></tr>
<tr><td class="e">SERVER_NAME </td><td class="v">rockster.informatik.uni-kl.de </td></tr>
<tr><td class="e">SERVER_ADDR </td><td class="v">131.246.103.120 </td></tr>
<tr><td class="e">SERVER_PORT </td><td class="v">8081 </td></tr>
<tr><td class="e">REMOTE_ADDR </td><td class="v">217.185.157.195 </td></tr>
<tr><td class="e">DOCUMENT_ROOT </td><td class="v">/home/n_faust/software/projekt/htdocs </td></tr>
<tr><td class="e">SERVER_ADMIN </td><td class="v">n_faust at informatik.uni-kl.de </td></tr>
<tr><td class="e">SCRIPT_FILENAME </td><td class="v">/home/n_faust/software/projekt/cgi-bin/php </td></tr>
<tr><td class="e">REMOTE_PORT </td><td class="v">1141 </td></tr>
<tr><td class="e">REDIRECT_URL </td><td class="v">/php_test.php4 </td></tr>
<tr><td class="e">GATEWAY_INTERFACE </td><td class="v">CGI/1.1 </td></tr>
<tr><td class="e">SERVER_PROTOCOL </td><td class="v">HTTP/1.1 </td></tr>
<tr><td class="e">REQUEST_METHOD </td><td class="v">GET </td></tr>
<tr><td class="e">QUERY_STRING </td><td class="v"><i>no value</i> </td></tr>
<tr><td class="e">REQUEST_URI </td><td class="v">/php_test.php4 </td></tr>
<tr><td class="e">SCRIPT_NAME </td><td class="v">/cgi-bin/php </td></tr>
<tr><td class="e">PATH_INFO </td><td class="v">/php_test.php4 </td></tr>
<tr><td class="e">PATH_TRANSLATED </td><td class="v">/home/n_faust/software/projekt/htdocs/php_test.php4 </td></tr>
</table><br />
<h2>PHP Variables</h2>
<tr><td class="e">PHP_SELF </td><td class="v">/php_test.php4 </td></tr>
<tr><td class="e">_SERVER["REDIRECT_STATUS"]</td><td class="v">200</td></tr>
<tr><td class="e">_SERVER["LD_LIBRARY_PATH"]</td><td class="v">/home/n_faust/software/projekt/lib</td></tr>
<tr><td class="e">_SERVER["HTTP_ACCEPT"]</td><td class="v">image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, */*</td></tr>
<tr><td class="e">_SERVER["HTTP_ACCEPT_LANGUAGE"]</td><td class="v">de</td></tr>
<tr><td class="e">_SERVER["HTTP_ACCEPT_ENCODING"]</td><td class="v">gzip, deflate</td></tr>
<tr><td class="e">_SERVER["HTTP_USER_AGENT"]</td><td class="v">Mozilla/4.0 (compatible; MSIE 6.0; Windows 98)</td></tr>
<tr><td class="e">_SERVER["HTTP_HOST"]</td><td class="v">rockster.informatik.uni-kl.de:8081</td></tr>
<tr><td class="e">_SERVER["HTTP_CONNECTION"]</td><td class="v">Keep-Alive</td></tr>
<tr><td class="e">_SERVER["PATH"]</td><td class="v">/opt/kde3/bin:/opt/gnome/bin:/usr/games:/usr/bin/X11:/usr/bin:/bin:/usr/local/bin:/home/n_faust/software/postgresql-7.4.5/bin:/opt2/jdk-1.4/bin:.</td></tr>
<tr><td class="e">_SERVER["SERVER_SIGNATURE"]</td><td class="v">&lt;address&gt;Apache/2.0.52 (Unix) Server at rockster.informatik.uni-kl.de Port 8081&lt;/address&gt;
</td></tr>
<tr><td class="e">_SERVER["SERVER_SOFTWARE"]</td><td class="v">Apache/2.0.52 (Unix)</td></tr>
<tr><td class="e">_SERVER["SERVER_NAME"]</td><td class="v">rockster.informatik.uni-kl.de</td></tr>
<tr><td class="e">_SERVER["SERVER_ADDR"]</td><td class="v">131.246.103.120</td></tr>
<tr><td class="e">_SERVER["SERVER_PORT"]</td><td class="v">8081</td></tr>
<tr><td class="e">_SERVER["REMOTE_ADDR"]</td><td class="v">217.185.157.195</td></tr>
<tr><td class="e">_SERVER["DOCUMENT_ROOT"]</td><td class="v">/home/n_faust/software/projekt/htdocs</td></tr>
<tr><td class="e">_SERVER["SERVER_ADMIN"]</td><td class="v">n_faust at informatik.uni-kl.de</td></tr>
<tr><td class="e">_SERVER["SCRIPT_FILENAME"]</td><td class="v">/home/n_faust/software/projekt/cgi-bin/php</td></tr>
<tr><td class="e">_SERVER["REMOTE_PORT"]</td><td class="v">1141</td></tr>
<tr><td class="e">_SERVER["REDIRECT_URL"]</td><td class="v">/php_test.php4</td></tr>
<tr><td class="e">_SERVER["GATEWAY_INTERFACE"]</td><td class="v">CGI/1.1</td></tr>
<tr><td class="e">_SERVER["SERVER_PROTOCOL"]</td><td class="v">HTTP/1.1</td></tr>
<tr><td class="e">_SERVER["REQUEST_METHOD"]</td><td class="v">GET</td></tr>
<tr><td class="e">_SERVER["QUERY_STRING"]</td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">_SERVER["REQUEST_URI"]</td><td class="v">/php_test.php4</td></tr>
<tr><td class="e">_SERVER["SCRIPT_NAME"]</td><td class="v">/cgi-bin/php</td></tr>
<tr><td class="e">_SERVER["PATH_INFO"]</td><td class="v">/php_test.php4</td></tr>
<tr><td class="e">_SERVER["PATH_TRANSLATED"]</td><td class="v">/home/n_faust/software/projekt/htdocs/php_test.php4</td></tr>
<tr><td class="e">_SERVER["PHP_SELF"]</td><td class="v">/php_test.php4</td></tr>
<tr><td class="e">_SERVER["argv"]</td><td class="v"><pre>Array
</pre></td></tr>
<tr><td class="e">_SERVER["argc"]</td><td class="v">0</td></tr>
<tr><td class="e">_ENV["REDIRECT_STATUS"]</td><td class="v">200</td></tr>
<tr><td class="e">_ENV["LD_LIBRARY_PATH"]</td><td class="v">/home/n_faust/software/projekt/lib</td></tr>
<tr><td class="e">_ENV["HTTP_ACCEPT"]</td><td class="v">image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, */*</td></tr>
<tr><td class="e">_ENV["HTTP_ACCEPT_LANGUAGE"]</td><td class="v">de</td></tr>
<tr><td class="e">_ENV["HTTP_ACCEPT_ENCODING"]</td><td class="v">gzip, deflate</td></tr>
<tr><td class="e">_ENV["HTTP_USER_AGENT"]</td><td class="v">Mozilla/4.0 (compatible; MSIE 6.0; Windows 98)</td></tr>
<tr><td class="e">_ENV["HTTP_HOST"]</td><td class="v">rockster.informatik.uni-kl.de:8081</td></tr>
<tr><td class="e">_ENV["HTTP_CONNECTION"]</td><td class="v">Keep-Alive</td></tr>
<tr><td class="e">_ENV["PATH"]</td><td class="v">/opt/kde3/bin:/opt/gnome/bin:/usr/games:/usr/bin/X11:/usr/bin:/bin:/usr/local/bin:/home/n_faust/software/postgresql-7.4.5/bin:/opt2/jdk-1.4/bin:.</td></tr>
<tr><td class="e">_ENV["SERVER_SIGNATURE"]</td><td class="v">&lt;address&gt;Apache/2.0.52 (Unix) Server at rockster.informatik.uni-kl.de Port 8081&lt;/address&gt;
</td></tr>
<tr><td class="e">_ENV["SERVER_SOFTWARE"]</td><td class="v">Apache/2.0.52 (Unix)</td></tr>
<tr><td class="e">_ENV["SERVER_NAME"]</td><td class="v">rockster.informatik.uni-kl.de</td></tr>
<tr><td class="e">_ENV["SERVER_ADDR"]</td><td class="v">131.246.103.120</td></tr>
<tr><td class="e">_ENV["SERVER_PORT"]</td><td class="v">8081</td></tr>
<tr><td class="e">_ENV["REMOTE_ADDR"]</td><td class="v">217.185.157.195</td></tr>
<tr><td class="e">_ENV["DOCUMENT_ROOT"]</td><td class="v">/home/n_faust/software/projekt/htdocs</td></tr>
<tr><td class="e">_ENV["SERVER_ADMIN"]</td><td class="v">n_faust at informatik.uni-kl.de</td></tr>
<tr><td class="e">_ENV["SCRIPT_FILENAME"]</td><td class="v">/home/n_faust/software/projekt/cgi-bin/php</td></tr>
<tr><td class="e">_ENV["REMOTE_PORT"]</td><td class="v">1141</td></tr>
<tr><td class="e">_ENV["REDIRECT_URL"]</td><td class="v">/php_test.php4</td></tr>
<tr><td class="e">_ENV["GATEWAY_INTERFACE"]</td><td class="v">CGI/1.1</td></tr>
<tr><td class="e">_ENV["SERVER_PROTOCOL"]</td><td class="v">HTTP/1.1</td></tr>
<tr><td class="e">_ENV["REQUEST_METHOD"]</td><td class="v">GET</td></tr>
<tr><td class="e">_ENV["QUERY_STRING"]</td><td class="v"><i>no value</i></td></tr>
<tr><td class="e">_ENV["REQUEST_URI"]</td><td class="v">/php_test.php4</td></tr>
<tr><td class="e">_ENV["SCRIPT_NAME"]</td><td class="v">/cgi-bin/php</td></tr>
<tr><td class="e">_ENV["PATH_INFO"]</td><td class="v">/php_test.php4</td></tr>
<tr><td class="e">_ENV["PATH_TRANSLATED"]</td><td class="v">/home/n_faust/software/projekt/htdocs/php_test.php4</td></tr>
</table><br />
<h2>PHP License</h2>
<tr class="v"><td>
<p>
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file:  LICENSE
</p>
<p>This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
</p>
<p>If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license at php.net.
</p>
</td></tr>
</table><br />
</div></body></html>
