small projection problem
Kana, David DKana at GEODIS.CZ
Tue Feb 1 10:25:28 EST 2005
It is also possible to define the PROJ_LIB environment variable to point to
the NAD directory or rebuild proj library with PROJ_LIB defined.
David Kana
-----Original Message-----
From: Ivan Mjartan [mailto:ivan.mjartan at GEOVAP.CZ]
Sent: Tuesday, February 01, 2005 4:09 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] small projection problem
Hi I have small problem with file epsg, because it's location in my project
(I am running on W2K and IIS) have to be
c:\proj\nad\epsg
Know somebody where can i redefine location of epsg file? I thing that i
have to make some change in code of mapserver but i dont known where.
thanks for your reply.
ivan mjartan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050201/38aa05f6/attachment.html
