PointObj draw labels
Rene Teniere tenierer at GOV.NS.CA
Tue Feb 1 11:38:30 EST 2005
I can't seem to be ablt to draw the annotation on the dynamic points added
using $fPoint->draw($map,$points,$image,$class,"Test");
I hope I do not need a labelitem, because I am drawing the points on an
empty point shapefile. Here is the mapfile:
Thanks,
Rene.
$image = $map->draw();
$class = 0;
$points = $map->getLayerByName("FLDCHKPTS");
$points->set("status", MS_ON);
$fPoint = ms_newPointObj();
$fPoint->setXY($fDownX[$i],$fDownY[$i]);
$rtres = $fPoint->draw($map,$points,$image,$class,"Test");
$fPoint->free();
  LAYER
    NAME "FLDCHKPTS"
    STATUS ON
    TYPE POINT
    MAXSCALE 500000
    DATA "D:/forestry/xtras/empty"
    CLASS
      NAME "Field Check Points"
      STYLE
        SYMBOL 7
        COLOR 0 150 0
        OUTLINECOLOR 0 0 0
        SIZE 10
        MINSIZE 1
        #MAXSIZE 100
      END
      LABEL
        TYPE BITMAP
        SIZE LARGE
        POSITION CR
        COLOR 0 0 0
      END
    END
  END
