Draw circle
Jeff Portwine jdport at VERITIME.COM
Wed Feb 2 11:24:37 EST 2005
Put something like this in your map file.    The numbers in the "points" section refer to the diameter in the X direction and the diameter in the Y direction.   If the numbers are the same you get a circle, otherwise you will get an ellipse.
SYMBOL
    NAME "circle"
    TYPE ellipse
    FILLED true
    POINTS
      12 12
    END
 END
-Jeff
  ----- Original Message -----
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Sent: Wednesday, February 02, 2005 11:02 AM
  Subject: [UMN_MAPSERVER-USERS] Draw circle
  Is there any easy way to draw a circle on a map without having to make it your self by drawing small lines?
  thank you
  Jose Luis
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050202/fa63469e/attachment.html
