Draw circle
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Feb 2 16:21:34 EST 2005
This sounds cool, is it in the documentation?
Steve Lime wrote:
> There is also a CIRCLE layer type. You can construct a shapefile of
> simple lines, 2 points per line. Where the points represent the bounding
> box for the circle (this works with inline features too). The LAYER
> might look like:
> LAYER
> NAME 'circles'
> TYPE CIRCLE
> DATA '/usr/local/data/circles'
> END
> Steve
>>>>Jeff Portwine <jdport at VERITIME.COM> 2/2/2005 10:24:37 AM >>>
> Put something like this in your map file. The numbers in the
> "points" section refer to the diameter in the X direction and the
> diameter in the Y direction. If the numbers are the same you get a
> circle, otherwise you will get an ellipse.
> SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED true
> POINTS
> 12 12
> END
> END
> -Jeff
> ----- Original Message -----
> From: Jose Luis Gonzalez
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Sent: Wednesday, February 02, 2005 11:02 AM
> Subject: [UMN_MAPSERVER-USERS] Draw circle
> Is there any easy way to draw a circle on a map without having to
> make it your self by drawing small lines?
> thank you
> Jose Luis
