Moving objects in MapServer
Bart van den Eijnden bartvde at XS4ALL.NL
Thu Feb 3 03:29:54 EST 2005
I don't know of any free out-of-the-box Mapserver solution which can
provide you with this functionality. Ofcourse it is possible to build such
a thing yourself with eg PHP/Mapscript if you have enough time on your
side.
The commercial IMF framework from Moximedia can do this out-of-the-box
though:
http://www.moximedia.com/imf.html
Best regards,
Bart
> To simplify things, I would like to show show some points on the map
> (coming from point shape file) and be able to move the point to another
> location on the map together with its attributes of course (for example,
> the map can be the map of my building and the points can be some objects
> in this building that can be moved from one room to another).
> Can it be done with MapServer, in a browser?
> Thanks
> Dejan
