Rotated Orthographic View?
H Z
hobbes_zatow at YAHOO.COM
Thu Feb 3 12:35:31 EST 2005
I have a US lower 48 state/county map view in ESRI ArcMap that I have
exported shapefiles out of, and use them in MapServer/PerlMapScript to
generate maps for the Web. When using a Mercator projection, everything
works fine, but now I need to use an orthographic projection. When using
ortho in ArcMap, the map appears rotated, but I can use ArcMap's Rotate Data
Frame tool to get it in the right position. Exporting the rotated map to a
shapefile and processing it in MapServer/PerlMapScript however doesn't
maintain the corrected rotation.
How can I have MapServer/PerlMapScript rotate the map prior to generating an
image from it?
Thanks!
