gdal utm .sid to lat/long .geotiff
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Feb 4 15:21:03 EST 2005
On Fri, 4 Feb 2005 18:28:22 +0100, joerg pfeiffer <superbla3000 at gmx.net> wrote:
> hello,
> I would like to convert a ETM+ Mosaic (250MB) from utm .sid to lat/long
> .geotiff to work with them in a mapserver map.
> So I downloaded the gdal FW tools for Windows, but it seems they cannot
> handle .sid.
> Then I tried the lizardtech mrsiddecode, but i canceled the conversion
> after 30 hours at 48%!
Yikes! Were you working on a local file system? Normally
mrsiddecode is reasonably fast. I think it might be prudent
for you to decode the mosaic in "chunks". I am pretty sure
there are mrsiddecode options for extracting subregions.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
