Problem with POINT layer in PostGIS
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Sun Feb 6 05:53:15 EST 2005
I submitted a bug for this (#1216). I have a table with point geoms and
another with polygon geoms. The polygon table displays as polygon, line, and
points. The point table doesn't display at all.
When converted to shapefile using pgsql2shp, the points display fine.
However, I need the database as it will be updated continually via a web
interface. The shapefile is not an option for me.
I've checked against 4.2.5, 4.4.1 and the CVS versions of MapServer and
neither would display the points. All the queries run properly in psql and
pgadmin.
-Perry
On Friday 04 February 2005 10:06 am, Dirk Jesko wrote:
> The log file shows no problem. Further, if I take the logged query and
> execute it within the psql shell it produces the correct result and the
> log is not significantly different. I still suppose that it is not a
> PostgreSQL/PostGIS problem.
> Dirk
> >Turn full logging on in PostgreSQL, attempt to render the map and see if
> > it provides any further information...
> >Drew.
Dept. of Ecology, Evolution, and Behavior
University of Minnesota
work: 612 624 6713
e-mail: nacional at cbs.umn.edu
