GDAL Make Fails
AJ Kertis akertis at GMAIL.COM
Mon Feb 7 17:01:28 EST 2005
I try to do a make and it fails in the ogr directory.
make[1]: Leaving directory `/home/mapserver/gdal-1.2.5/ogr/ogrsf_frmts'
/bin/sh ../libtool --mode=link  g++  ogrinfo.o ../libgdal.la -o ogrinfo
g++ ogrinfo.o -o .libs/ogrinfo  ../.libs/libgdal.so -
L/usr/local/lib /usr/local/lib/libgeos.so -L/usr/local/GeoExpress-
SDK//lib/Release -lltidsdk -lpthread -lgif /usr/lib/libjpeg.so -ltiff -
lpng -lz -ldl -L/usr/local/pgcluster/lib -lpq -Wl,--rpath -
Wl,/home/mapserver/lib
../.libs/libgdal.so: undefined reference to
`std::__default_alloc_template<true, 0>::allocate(unsigned int)'
../.libs/libgdal.so: undefined reference to `std::basic_string<wchar_t,
std::char_traits<wchar_t>, std::allocator<wchar_t> >::_Rep::_S_create
(unsigned int, std::allocator<wchar_t> const&)'
../.libs/libgdal.so: undefined reference to `std::basic_string<char,
std::char_traits<char>, std::allocator<char> >::_M_check(unsigned int)
const'
std::char_traits<char>, std::allocator<char> >::_Rep::_S_create(unsigned
int, std::allocator<char> const&)'
>::_S_empty_rep_storage'
std::char_traits<char>, std::allocator<char> >::_S_empty_rep_storage'
`std::__default_alloc_template<true, 0>::deallocate(void*, unsigned
int)'
collect2: ld returned 1 exit status
make: *** [ogrinfo] Error 1
I'm not sure what this means exactly or whats it not finding a ref to.
Any help would be much appreciated.
Thanks,
AJ Kertis
