showing lines of overlapping polygons
Erwin v.d. Bij ErwinVanderBij at CS.COM
Wed Feb 9 07:26:06 EST 2005
Hello,
I want to see the lines of 2 or more polygons which do overlap. Polygons are in the same layer. Polygons are filled with a style. Currently, I see only all the lines of the polygon which is obvious on top. I've experienced with the TRANSPARANCY attribute, but that did not help. Do you have any ideas?
