mapserv segfaults
John C Cartwright John.C.Cartwright at NOAA.GOV
Wed Feb 9 19:08:41 EST 2005
Hi Steve,
thanks for the prompt response and the suggestion.
gdb is just telling me the error occurred in memory allocation, but this
is not helping me much:
(gdb) run
Starting program: /extra/contrib/apache/cgi-bin/mapserver-4.4.1
[Thread debugging using libthread_db enabled]
[New Thread -1218617216 (LWP 8708)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1218617216 (LWP 8708)]
0x039ba0d1 in realloc () from /lib/tls/libc.so.6
I was hoping to tell what request parameter or map configuration element
might be causing trouble. Can you think of any way for me to pursue this
at a higher level?
Thanks!
-- john
Stephen Woodbridge wrote:
> John,
> You can run mapserver cgi at the command line, but you need to set up
> the environment variables first, like
> export REQUEST_METHOD=GET
> export QUERY_STRING="...."
> gdb mapserv
> run
> set your QUERY_STRING appropriately
> -Steve W.
