mapserv segfaults
John C Cartwright
John.C.Cartwright at NOAA.GOV
Thu Feb 10 11:47:12 EST 2005
Hi Sean,
thanks for the suggestion. here's the output:
(gdb) run
Starting program: /extra/contrib/apache/cgi-bin/mapserv-debug
[Thread debugging using libthread_db enabled]
[New Thread -1218604192 (LWP 19250)]
[Thu Feb 10 09:40:19 2005].204455 msWMSLoadGetMapParams(): enabling
non-square pixels.[Thu Feb 10 09:40:19 2005].208427 msDrawMap(): kicking
into non-square pixel preserving mode.
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1218604192 (LWP 19250)]
0x0095b0d1 in realloc () from /lib/tls/libc.so.6
Here's the query string:
map=/extra/contrib/apache/htdocs/mapserver/wms_wfs/wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=relief,cities_poly,counties,states,roads
and this is a RedHat ES 3 system (kernel 2.4.21-27.0.1.ELsmp)
Where should I go from here?
Thanks again!
-- john
Sean Gillies wrote:
> John, add a
> DEBUG ON
> to the Map-level block in your map config file. This will write
> messages to stderr, including names of layers being accessed. This
> should let you know which layer (if any) is associated with the segfault.
> Now that you've recompiled, run mapserv under gdb exactly as Steve
> Woodbridge described. This time gdb should give a more detailed
> description of the location of the memory error including all the
> MapServer functions that have been called. Give us a look at that and
> we can try to figure out what's going on.
> cheers,
> Sean
> On Feb 9, 2005, at 5:28 PM, John C Cartwright wrote:
>> Thanks, Sean. I recompiled with debugging, can you provide me a little
>> guidance on what would be helpful to get out of gdb?
>> Thanks again for your patience and help!
>> -- john
>> Sean Gillies wrote:
>>> John,
>>> Looks to me like you need to re-config mapserver with --enable-debug so
>>> that gdb can tell us more about the calling stack.
>>> cheers,
>>> Sean
>>> On Feb 9, 2005, at 5:08 PM, John C Cartwright wrote:
>>>> Hi Steve,
>>>> thanks for the prompt response and the suggestion.
>>>> gdb is just telling me the error occurred in memory allocation, but
>>>> this
>>>> is not helping me much:
>>>> (gdb) run
>>>> Starting program: /extra/contrib/apache/cgi-bin/mapserver-4.4.1
>>>> [New Thread -1218617216 (LWP 8708)]
>>>> [Switching to Thread -1218617216 (LWP 8708)]
>>>> 0x039ba0d1 in realloc () from /lib/tls/libc.so.6
>>>> I was hoping to tell what request parameter or map configuration
>>>> element
>>>> might be causing trouble. Can you think of any way for me to pursue
>>>> this
>>>> at a higher level?
>>>> Thanks!
>>>> -- john
>>>> Stephen Woodbridge wrote:
>>>>> John,
>>>>> You can run mapserver cgi at the command line, but you need to set up
>>>>> the environment variables first, like
>>>>> export REQUEST_METHOD=GET
>>>>> export QUERY_STRING="...."
>>>>> gdb mapserv
>>>>> run
>>>>> set your QUERY_STRING appropriately
>>>>> -Steve W.
