mapserv segfaults
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Feb 10 13:17:18 EST 2005
> (gdb) where
> #0 0x006a10d1 in realloc () from /lib/tls/libc.so.6
> #1 0x007bb3dd in _TIFFrealloc () from
> /extra/contrib/esri/sdeexe90/lib/libtiff.so
John,
Any chance you have the PDF libraries linked into MapServer? Some
versions have a copy of libtiff built-in that can conflict with the
GDAL version.
If you don't need PDF support just reconfigure and rebuild MapServer
without it. If you do need it, look into upgrading to the latest version in
which this problem is reportedly fixed.
There was some discussion of this on the mailing list last fall when
I first encountered the problem.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
