Install Problem - error loading libgd
Jeff Berry
jeffb at ERLANDSEN.COM
Thu Feb 10 18:03:38 EST 2005
Im installing MapServer on a new server running Linux RedHat ES. Ive
installed gd-2.0.33. After compiling mapserver and running it at the
command line to see if its working, I get the following error:
./mapserv: error while loading shared libraries: libgd.so.2: cannot open
shared object file: No such file or directory
I do indeed have libgd.so.2 installed in /usr/local/lib. The configuration
setup I used for mapserver is:
./configure with-freetype=/usr/local/include/freetype2/freetype with-zlib=
/usr/local with-gd=/usr/local with-proj=/usr/local with-gdal=/usr/local/b
in/gdal-config with-php=/usr/local
Any ideas why mapserver cant see the library? Im at a loss.
-Jeff
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050210/6cd6f25d/attachment.html
