PostGIS vs. Shapefile
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Fri Feb 11 04:10:08 EST 2005
A SQL query (using psql) like this:
SELECT * FROM ra_strade WHERE gid >= 0 ;
(i.e., all 33000 records) outputed to a file, takes about 3 seconds.
I will try debug options (decommenting and setting them to "true"), to
see if there's something strange.
Daniele
-----Original Message-----
From: Miroslav Šulc [mailto:miroslav.sulc at startnet.cz]
Sent: Friday, February 11, 2005 9:38 AM
To: Daniele Margotti
Subject: Re: [UMN_MAPSERVER-USERS] PostGIS vs. Shapefile
And how long does it take when you perform some SELECTs with WHERE
clause directly at the PosgreSQL server (with psql or something
similar)? I don't know how to create PostGIS WHERE clauses so I cannot
give you a tip but maybe someone can help or you can find an example
somewhere. It would be best to issue the same query as mapserver does.
I think that if the queries will take long time then the problem may be
in PostgreSQL else the problem may be somewhere between mapserver and
PostgreSQL or mapserver itself.
You can also try to use some of these debug options in your
postgresql.conf: #debug_print_parse = false #debug_print_rewritten =
false #debug_print_plan = false #debug_pretty_print = false
#log_connections = false #log_disconnections = false #log_duration =
false I have PostgreSQL 8.0.1 and I don't know whether these options are
present in your version. Some of these options look pretty interesting.
Miroslav Šulc
Daniele Margotti wrote:
>My connection string is:
>DATA "the_geom from my_table01"
>CONNECTION "user=postgres dbname=my_database host=localhost port=5432"
>CONNECTIONTYPE postgis
>Where can I find logs?
>I installed PostgreSQL via RPMs, which did put the program in
>/var/lib/pgsql:
># ls -al /var/lib/pgsql/data/
>totale 52
>drwx------ 6 postgres postgres 4096 10 feb 16:37 .
>drwx------ 4 postgres postgres 4096 10 feb 17:02 ..
>drwx------ 5 postgres postgres 4096 10 feb 12:38 base
>drwx------ 2 postgres postgres 4096 11 feb 09:09 global
>drwx------ 2 postgres postgres 4096 8 feb 15:57 pg_clog
>-rw------- 1 postgres postgres 2572 10 feb 10:13 pg_hba.conf
>-rw------- 1 postgres postgres 1441 8 feb 15:58 pg_ident.conf
>-rw------- 1 postgres postgres 4 8 feb 15:57 PG_VERSION
>drwx------ 2 postgres postgres 4096 10 feb 13:09 pg_xlog
>-rw------- 1 postgres postgres 5238 9 feb 14:03 postgresql.conf
>-rw------- 1 postgres postgres 32 10 feb 15:17 postmaster.opts
>-rw------- 1 postgres postgres 45 10 feb 15:17 postmaster.pid
>In pg_clog and pg_xlog I have no text logs, only data files that are
>not comprehensible.
> Daniele
