edge problems in shp
Yogid yogid at O2.PL
Sat Feb 12 13:28:29 EST 2005
Witaj Stephen,
SW> Just looking at the images is hard to tell, but it looks like you are
SW> missing the last point of the polygons. Look specifically at polygons
SW> with  4 sides in the openev_fw.gif and compare them to the
SW> map_server.gif and you will see that the map_server.gif polygons are all
SW> triangles which suggests that the final point did not make it into the
SW> polygon. Now if you assume this is the problem the other polygons seem
SW> to have the same issue and make more sense.
SW> I can say why, but maybe the final index was stored as the count (oops,
SW> off by one) or the loop copying the points has an off by one problem.
SW> -Steve W.
Thank you for your answer. I still don't known what was wrong but I
edit layer (.shp) in open_ev and save it. When I make new map file with
this new .shp all is ok, it is good show. Maybe wintopo save it in other
way/format (int, double, other round count).
Thank you one more time :]
Daniel D.
