mapserver with java support
Umberto Nicoletti
unicoletti at PROMETEO.IT
Mon Feb 14 09:48:19 EST 2005
On Mon, 2005-02-14 at 16:25 +0200, temiz wrote:
> Umberto Nicoletti wrote:
> >The basic steps to get java mapscript going are:
> >1) compile mapserver. the following options are strongly suggested:
> >--use-threads --use-proj
> >2) cd to mapscript/java
> >3) read README
> >4) optionally run make interface (in your case you shouldn't)
> >4) run make
> >5) run the examples: make test
> >HTH,
> >Umberto
> >On Mon, 2005-02-14 at 15:41 +0200, temiz wrote:
> >>hello
> >>is this correct to compile mapserver with java support ?
> >>--with-java=/usr/local/j2sdk1.4.2_07/ \
> >>I am confused on mapserver - java installation in wiki's page
> >>is there any page or which shows steps to build an application for java?
> >>regards
> >>______________________________________
> >>XamimeLT - installed on mailserver for domain @deprem.gov.tr
> >>Queries to: postmaster at deprem.gov.tr
> >>The views and opinions expressed in this e-mail message are the sender's own
> >>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> >>of General Directorate of Disaster Affairs.
> >>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> >>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
> thank you for your help
> I am not clear on what the usage of "--use-threads --use-proj" is ?
Sorry, I did not make clear that they are configure options.
--use-threads provides thread safety support in java mapscript. This is
*compulsory* if you want to use mapscript in servlets or jsps
--with-proj is not necessary, but I found that not using it could lead
to
unresolved compilation symbols in libmapscript.so. You might want to
skip this option the first time. It requires proj to be installed.
Regards,
Umberto
> regards
> Ahmet Temiz
Umberto Nicoletti <unicoletti at prometeo.it>
Prometeo SRL
