Musmap 0.8 released
Mathieu Parent
mathieuparent at USERS.SOURCEFORGE.NET
Mon Feb 14 14:33:50 EST 2005
Musmap is a web mapping application build with PHP/Mapscript.
Musmap provides a lot of feautres:
- query by point (click) and box
- query by form (administrable)
- query results can be stored (some known bugs here)
- zoom, pan, ...
and advanced features ...
- map configuration (using a tree-view called "profile explorer") with a
class wizard (select a field, choose min and max values : it will make
graduating colors)
- users and groups administration (privileges)
- metadata with label, column type, joins, ... used for query results
(from an address you can go to a road if they are linked, and from a
road you can see all of its adresses !)
- a lot of mapserver features are available and customizable
(projections, ogr, wms, wfs, ...)
- Musmap is a multilingual application, currently french and english are
completely done
- i should forget a lot
more infos at http://musmap.sourceforge.net/
(report bugs and feature requests from this site)
