RES: [UMN_MAPSERVER-USERS] php/mapscript bug - URGENT
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Mon Feb 14 23:48:54 EST 2005
I tested fastcgi now (for php-mapscript, not mapserv-cgi), it's
definitely faster, and is a great option for php-dso...
Hope that helps,
Murilo
-----Mensagem original-----
De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Em
nome de Stephen Woodbridge
Enviada em: terça-feira, 15 de fevereiro de 2005 00:08
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: Re: [UMN_MAPSERVER-USERS] php/mapscript bug - URGENT
Murilo,
I'm not sure anyone can say it works definitively, so the safe answer is
do not use the DSO version, especially if you are have problems with it.
Mapserver working in a DSO is very new and we as a group have very
little experience with it.
If you can afford to help us out testing and reporting results using the
DSO version that would be grand, but if you need to get you site up and
working reliably, we all know that the cgi stuff works and works well.
You can run all your other non mapscript code using the DSO, just
configure apache to use the CGI version for the directories that contain
mapscript.
-Steve W.
Murilo Lacerda Yoshida wrote:
> Hi all,
> This is about that saveWebImage bug, that shows random images to the
> user.
> I am going to install a second php on my server, as a cgi, and run
> mapscript on it. The problem is that I have several pages that do not
> show images on screen, these pages does some stuff like creating
> shapefiles, making a projection conversion, this kind of stuff.
> What I wanted to know is if this image bug is restricted to the
> images... Can I still use mapscript with php-dso when I don't how
> images?
> I think that I can, but I'm not sure.
> Thanks,
> Murilo
