PHP MapScript installation problem
Jussi Rasinmäki jussi.rasinmaki at HELSINKI.FI
Tue Feb 15 12:44:47 EST 2005
Hi Fernando,
Thanks! Problem solved. Couldn't get the Apache SetEnv to work at least at
first try but the edit of ld.so.conf followed with ldconfig did the trick.
Jussi
----- Original Message -----
To: "Jussi Rasinmäki" <jussi.rasinmaki at HELSINKI.FI>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, February 15, 2005 4:55 PM
Subject: Re: [UMN_MAPSERVER-USERS] PHP MapScript installation problem
> Hi Jussi,
>     I believe that the best way to fix this is setting a variable for
> apache web server. Another way is include the path for library in
> ld.so.conf.
>     Here I defined this in httpd.conf of apache:
>        SetEnv LD_LIBRARY_PATH
> "/opt/oracle/product/10.1.0/client_1/lib:/lib:/usr/lib:/usr/local/lib"
>     Thanks.
> Fernando Simon
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada - Brazil
> http://g10.cttmar.univali.br - UNIVALI/CTTMAR
> Jussi Rasinmäki wrote:
> >Hi,
> >I've tried to install Mapserver with PHP Mapscript on Whitebox Linux 3,
but
> >have run into difficulties with PHP and php_mapscript.so.
> >dl("php_mapscript.so") returns the following warning:
> >Warning: dl(): Unable to load dynamic library
> >'/usr/local/php/extensions/php_mapscript.so' - libclntsh.so.10.1: cannot
> >open shared object file: No such file or directory in
/var/www/html/info.php
> >on line 7
> >PHP 4.3.10 is installed using the following configuration:
>./configure --enable-shared --with-jpeg-dir=/usr --with-png-dir=/usr --with
>zlib --with-gd=/usr/local --with-freetype-dir=/usr --enable-force-cgi-redir
e
> >ct --with-config-file-path=/usr/local/php/ --prefix=/usr/local/php
> >and the php.ini in /user/local/php has the following line:
> >extension_dir = "/usr/local/php/extensions/"
> >Mapserver is configured as:
>./configure --without-tiff --without-eppl --with-threads --with-proj --with
>gdal --with-oraclespatial=/opt/app/oracle/product/10.1.0/Db_1 --with-php=/o
p
t/app/mapserver/mapserver_libs/php-4.3.10 --with-gd=/usr/local  --with-freet
> >ype=/usr/bin --with-wmsclient
> >and the built php_mapscript.so is copied to /usr/local/php/extensions
> >However, php-config --extension-dir returns
> >/usr/local/php/lib/php/extensions/no-debug-non-zts-20020429
> >which is a non-existing directory.
> >What went wrong?
> >Thanks,
> >Jussi Rasinmäki
