troubles on GIF symbols transparency
Flavio Hendry flavio at TYDAC.CH
Wed Feb 16 12:48:02 EST 2005
ciao francesco
the problem might be related to your output format (IMAGETYPE). I
suppose you are using jpeg or png24. use png or gif .... (such as
IMAGETYPE PNG).
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############      Mit freundlichen Gruessen / Kind Regards
############             mailto:flavio at tydac.ch
############         TYDAC AG - http://www.tydac.ch
####    ####        Geographic Information Solutions
####    ####         Luternauweg 12 -- CH-3006 Bern
############   Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: MAPSERVER-USERS at lists.umn.edu
Date: Wed, 16 Feb 2005 15:19:35 +0100
Subject: [UMN_MAPSERVER-USERS] troubles on GIF symbols transparency
> Hi all,
> I would like to define symbols with GIF images. In these images I
> would set white color as transparent.
> The problem is that mapserver draws white parts as fill white and not
> as transparent.
> In symbol file I define as follows:
> #1007
> Symbol
> Name 'test'
> Type PIXMAP
> Image 'c:\trash\test.gif'
> Transparent 0
> END
> I also tried to set Trasparent as 1 or 254 or 255, but nothing
> changes.
> Anybody as any suggestions?...
> Best regards
> Francesco Sozzi
