'PVALUE' error with PROJ4 when building PHP MapScript??
Bob Bruce
covariance at SHAW.CA
Fri Feb 18 08:32:31 EST 2005
Thanks Yewondwossen:
I made this change and it worked for me, I managed to
build everything and tested the PHP MapScript and it worked! Now I can
start working on some changes to the code.
Thanks again,
Bob Bruce, Winnipeg, Manitoba
On Thu, 17 Feb 2005 10:00:29 -0500, Yewondwossen Assefa
<assefa at DMSOLUTIONS.CA> wrote:
>I had encoutnter this problem too. The way I solved it is by modifying
>the proj source code at a couple of places by replacing the PVALUE by
>PARAMVALUE. There are only few occurences :
> - 2 occurences in .../src/pj_params.c
> - 2 occurences in .../src/projects.h
> After these changes the build was ok.
> Frank, Is it possible to make these changes in the CVS or does this
>have other effects ?
>later
>Bob Bruce wrote:
>> I have been trying to build the nightly build of MapServer, specifically
>> PHP MapScript with PHP5 on a WIN2K system and have just got an error on a
>> link that has me stumped and am wondering if someone can help me -
please?
>> The error is:
>> C:\Program Files\Microsoft Visual Studio\VC98\include\winreg.h(88) :
error
>> C2371: 'PVALUE' : re
>> definition; different basic types
>> c:\projects\proj-4.4.9/src\projects.h(178) : see declaration
>> of 'PVALUE'
>> which seems to indicate that there is a conflict between the definition
of
>> PVALUE in a VC++6 include file and a PROJ4 include file.
>> I have built MapServer with WMS Client and Server and WFS Client and
Server
>> support to overcome build errors that I reported earlier this week. Now I
>> have hit this error.
>> thanks in advance for your help,
>> The statement in the build that this error occurs in is:
>> link /NODEFAULTLIB:libcd /dll /debug /out:php_mapscript.dll
>> php_mapscript_util.obj php_
>> mapscript.obj mapscript_i.obj ../../mapserver_i.lib
>> c:/projects/gdwin32/bgd.lib c:\proje
>> cts\proj-4.4.9/src/proj_i.lib c:\projects\gdal-1.2.5/gdal_i.lib
>> C:/Projects/curl-7.13.0/lib/li
>> bcurl.lib "C:\Program Files\Microsoft Visual Studio\VC98
>> \Lib\WSOCK32.LIB" C:\php-5
>> .0.3\lib\php5ts.lib
>> Microsoft (R) Incremental Linker Version 6.00.8447
>> Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
>> Creating library php_mapscript.lib and object php_mapscript.exp
>> cl /nologo /Zi /W3 /DDEBUG /Fdphpms.pdb -DWIN32 -
>> D_WIN32 /DZEND_WIN32 /DPHP_WIN32 /DPHP
>> 4 /DZTS -Ic:/projects/gdwin32 -Ic:\projects\proj-4.4.9/src -IC:\php-
>> 5.0.3/regex -DPHP_NO_AL
>> IASES -Ic:\projects\gdal-1.2.5/ogr/ogrsf_frmts -Ic:\projects\gdal-
>> 1.2.5/ogr -Ic:\projects\gdal
>> -1.2.5/port -IC:/Projects/curl-7.13.0/include -
DHAVE_STRING_H -
>> DREGEX_MALLOC -DNEED_
>> STRCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT -DWIN32 -D_WIN32 -
>> DUSE_PROJ -DUSE_PROJ_API_H
>> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF -
>> DGD_HAS_GDIMAGEGIFPTR -DUSE_GD_FT -DGD_
>> HAS_GETBITMAPFONT -DUSE_OGR -DUSE_WMS_SVR -DUSE_WMS_LYR -
>> DIGNORE_MISSING_DATA -DENABLE_STDER
>> R_DEBUG -DUSE_WFS_SVR -DUSE_WFS_LYR -DUSE_GD_ANTIALIAS -
I../.. -
>> IC:\php-5.0.3 -IC:\
>> php-5.0.3/main -IC:\php-5.0.3/zend -IC:\php-5.0.3/include -IC:\php-
>> 5.0.3/tsrm /DCOMPILE_DL=1 /c
>> php_proj.c /Fophp_proj.obj
>> php_proj.c
error
>> of 'PVALUE'
>> C:\php-5.0.3/main\php_regex.h(36) : warning C4005: 'PHP_NO_ALIASES' :
macro
>> redefinition
>> unknown(0) : see previous definition of 'PHP_NO_ALIASES'
>> NMAKE : fatal error U1077: 'cl' : return code '0x2'
>> Stop.
>Assefa Yewondwossen
>Software Analyst
>Email: assefa at dmsolutions.ca
>http://www.dmsolutions.ca/
>Phone: (613) 565-5056 (ext 14)
>Fax: (613) 565-0925
